Old 04-20-2013, 10:17 PM   #391
jtstromsburg's Avatar
Originally Posted by LaydBack View Post
Has anyone had the issue of the AC fan coming on when you set the thermostat to furnace/heat? Both of mine do it, but the furnace actually comes on with the main thermostat. It didn't always do it, and I can't say that I ever tried turning the 2nd AC's thermostat to furnace. It definitely doesn't seem that the compressor runs.
If your stat is like mine, it is a Common problem that dealers should explain, but don't. Cycle thru to fan, then adjust it to auto instead of hi or low. Then back to heat and you should be good.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is online now   Reply With Quote
Old 04-20-2013, 10:18 PM   #392
Fulltime family RVer
This sounds snotty but isn't meant to be - but, read the manual. There's a setting that makes it do this. (Or so I've read in here.)
Mine doesn't do that.
ependydad is online now   Reply With Quote
Old 04-20-2013, 10:28 PM   #393
LaydBack's Avatar
Thanks, that nailed it.
Thanks.....looked there first.....my manual doesn't even show the stat I have, let lone offer the solution given above. Doesn't appear I got a manual for the stat.
LINK TO MY MODS
2012 F350 King Ranch DRW 6.7L
2013 Sabre 36QBOK-7 Platinum Package
LaydBack is offline   Reply With Quote
Old 04-20-2013, 10:45 PM   #394
Glad he had better directions than I did! Strange- but I got an actual thermostat manual. My generic one is ok-to-fair, but not specific enough to be helpful.
I think there's and electronic copy of the manual in the files section of the site.
Old 04-20-2013, 10:52 PM   #395
LaydBack's Avatar
Thanks, I'll look for it. I even tried Dometic's site....but couldn't come across an instruction manual for the stat. I pulled the control box from behind the AC filter cover, and was able to get an idea of what was going on, but hadn't given thought to the 3rd fan setting (auto).
LINK TO MY MODS
Old 04-21-2013, 10:29 AM   #396
Has anyone figured out a way to get more pressure out of the shower head? I have a pressure regulator set to 60.
bluflame11 is offline   Reply With Quote
Old 04-21-2013, 10:33 AM   #397
QCCowboy's Avatar
Just responded to your other post in the mods section asking the same question.
Jack of all trades - Master of none
2012 F350 CC DRW - 6.7L PSD
2014 Sabre 36QBOK
QCCowboy is offline   Reply With Quote
Old 04-21-2013, 10:35 AM   #398
thanks, SW just had her first shower and she was not really happy with the pressure pressure
Old 04-21-2013, 10:35 AM   #399
DW
Old 04-21-2013, 10:38 AM   #400
QCCowboy's Avatar
Mine was always the same way until i put the Oxygenics in.....just as good as home now.
2014 Sabre 36QBOK
