Old 06-02-2013, 09:29 PM   #561
QCCowboy's Avatar
Originally Posted by Brandon327 View Post
We have to dump every day on gray water in the tank with a shower for a family of 5 with short showers
Is that while on full hookups?
Jack of all trades - Master of none
2012 F350 CC DRW - 6.7L PSD
2014 Sabre 36QBOK
QCCowboy is offline   Reply With Quote
Old 06-02-2013, 09:29 PM   #562
Fulltime family RVer
Originally Posted by QCCowboy View Post
Yep... Just looked at the specs. Except the OK tank. I don't think it can be 42 can it?
It's 42 from what I know- silly if you ask me, but it is. I still wish they plumbed the 1/2 bath sink to that tank instead of the black. But there's likely a reason. I know it takes over 10 minutes to fill by running that sink faucet.
On the bright-side, when you overflow that sink (twice.. doh!), it doesn't flow back into the bedroom since it's on a slide.
Old 06-02-2013, 09:31 PM   #563
My family of 3-4 does the same. If I'm on full hookups, I usually leave the gray open. If I'm without sewer hookups, we use the bathhouse.
Old 06-02-2013, 09:32 PM   #564
QCCowboy's Avatar
Seems to fill way to fast to be 42. I agree on the plumbing, but oh well. Way too many things I like about it to worry about that one.
2014 Sabre 36QBOK
Old 06-02-2013, 09:40 PM   #565
We have everything but sewer hookups where we are at. We have a 1 year old so the bathhouse are a negative. They have a pump out service here though. I wish the tanks held more though. It seems as though the kitchen sink tanks is filling up quick. We have not washes much and it is 2/3 full and it was emptied this morning. Where does the washer empty into?
Brandon327 is offline   Reply With Quote
Old 06-02-2013, 09:47 PM   #566
QCCowboy's Avatar
Don't know about that one as we don't have a washer, but my guess would be the same gray as the shower.
My kitchen fills slow but unless we are on full hookups we fill one side half full with hot soapy water and the other with cold water to rinse. Camping with electric only helped us learn how to conserve quite a bit. My biggest problem then is running out of fresh water. Bought a 5 gallon water container and a battery operated siphon to refill with.
2014 Sabre 36QBOK
Old 06-04-2013, 05:30 PM   #567
What is the coldest setting on the outside kitchen fridge?
Old 06-04-2013, 10:26 PM   #568
Cold enough to freeze beverages in my case.
Old 06-04-2013, 10:27 PM   #569
QCCowboy's Avatar
X2....
2014 Sabre 36QBOK
Old 06-04-2013, 10:28 PM   #570
Is it 1 or 7? Mine don't seem to be getting that cold on 7 so I turned it to 1 and I am waiting to see what happens. I had it in 7 and some meat ruined in it.
