02-02-2014, 05:29 PM
#681
Always Learning
Originally Posted by Pirates55
Please tell me more about these quadra steps. The fact that it only had 3 steps was a negative for me when buying. I did like the 4 steps that the Columbus 385 bh had. Do the quadra steps simply bolt on and I assume there is plenty enough room for them to fold up.
What brand will work and where do you get them.
Unfortunately I don't have any answers for you. I think I had picked the Elkhart Tool and Dye (sp?) because they seemed to be one of the first 4-steps that I found. It sounds like they mostly fit. I thought someone had posted some info and pictures about an actual install a while back.
We carry a pair of "Safety Steps" that had adjustable feet everywhere we go. If we don't use them at the doors, we put them below the outside kitchen. $100/each, but really nice.
02-05-2014, 01:37 PM
#682
I installed the Elkhart Tool & Die ones. The pics are in the 36QBOK mods thread.
Sent from my SPH-L710 using Forest River Forums mobile app
LINK TO MY MODS
2012 F350 King Ranch DRW 6.7L
2013 Sabre 36QBOK-7 Platinum Package
04-22-2014, 11:42 AM
#683
Always Learning
Seems like a good time to revive this thread. With the help of my brother-in-law and father-in-law, we measured my 36QB while it was hitched up to the truck. Came in right at 13' 4 1/2".
Now to print that on a label maker and put it onto the truck windshield.
04-22-2014, 11:49 AM
#684
Is that the low profile a/c or standard a/c?
04-22-2014, 11:54 AM
#685
Always Learning
I assume standard as I only opted for the 2nd A/C when I ordered and didn't specifically make any requests for a low profile unit. It's pretty bulky, so I can't imagine it's low profile.
04-22-2014, 03:53 PM
#686
I will measure mine when I get it back from the dealer with completed warranty repairs next week. I expect to measure close to the same as my 2nd a/c is high profile also. Every time I approach a bridge, evev in my car, I am wodering...would I clear this? What method did you use to measure?
2018 Heartland Landmark 365 Charleston
2008 Ford F350 King Ranch CC DRW 6.4l, 4.10 diff
B&W companion
Airlift system/on board compressor
04-22-2014, 04:05 PM
#687
Always Learning
I took a furring strip about 6' long and put a torpedo level on top. I made sure the board was level as we extended from the A/C (highest point) out over the side of the camper. My brother in law (on the roof with me) then held then tape measure to the end of it and lowered it to my father in law. The street my FIL lives on is pretty level, so we just did it down to street level.
04-23-2014, 12:50 PM
#688
Always Learning
So now- a few more measurements because I'm the curious sort. Between the highest point of my bedrails (which is actually a ridge on the top of my Retrax Pro cover) and the lowest point under the overhang (which is a seam) is between 5 3/4" and 6".
My truck when loaded squats almost exactly 2" in the rear (measured at a point on the wheel fender to the ground). When loaded, my truck's front doesn't change at all (same measurement method).
04-25-2014, 10:33 PM
#689
We have a 2013 36QBOK have pulled it.....somewhere near 5K miles..... we have pulled it up some pretty big mountains and across a lot of Texas. We love it. Only downsides we have found...we would like a little bigger oven and the original stove grate was pretty cheaply made but the replacement is much better, and we replaced the couch in the living area with a double recliner as we didnt need the extra bed and wanted more comfy seating.
John and Aptil
2013 Sabre 36QBOK
Ford F350 7.3 Powerstroke Crewcab
Full Time
04-26-2014, 08:47 AM
#690
What do you pull it with?
04-26-2014, 09:22 AM
#691
Always Learning
Me- Ram 3500 dually.
04-26-2014, 09:27 AM
#692
We pull it with a f350 crew cab long box single 7.3L powerstroke
Sent from my SAMSUNG-SGH-I527 using Forest River Forums mobile app
John and Aptil
2013 Sabre 36QBOK
Full Time
04-26-2014, 10:00 AM
#693
I pull mine with an F-350 diesel short bed
05-18-2014, 08:59 PM
#694
F350 is the only way to go!
05-26-2014, 07:29 PM
#695
Finally got around to measuring the height before our trip this weekend with the help of my son. I used the same method you used above and measured at 13'4"...pretty close to your measurements. I'm getting more comfortable with bridge over/under passes but sometimes those low hanging utility lines frighten me
B&W companion
05-26-2014, 08:13 PM
#696
Always Learning
Any Sabre 36QBOK's out there?
What scares me are low hanging branches on small streets. Hit one pretty good as I was watching an obstacle on the road vs. looking up (1/4-mile from my house, on my street no less!). No damage fortunately, but it did send my fat tush up the ladder onto the roof once we got home.
05-26-2014, 08:16 PM
#697
Oklahoma Proud
What is everybody doing with all thier sewer hoses?
Do you use a tub? several pvc post storage units?
I have one pvc post storage drawer tube from my last trailer.
I also got a couple of these from my buddy, but would like to use one for all my black/gray fittings and gray wash/rinse hoses. The other I was wanting to use for fishing poles and other "clean" stuff.
So just wondering what ya'll use, or if I just need to make more pvc storage tubes.
MillerTime- Future Sabre Handler!!
05-26-2014, 08:18 PM
#698
Oklahoma Proud
Oh yeah, I'm trying to figure this out cause we're picking up our 36 Wednesday!!!
05-26-2014, 08:20 PM
#699
Always Learning
I carry between 40' and 60' of sewer hose (used to have 60' then they developed pin hole leaks and now I'm at 40' in 4x10' sections). It all rides in two sewer tubes made of fence post and gutters.
I also carry a wye (and 3 caps for it), two 90-degree elbows (not sure why I have 2, I just do!) and a sewer donut that ride in a small closeable tote. This rides in the basement.
I leave my clear elbows always mounted on my sewer connections.
05-27-2014, 06:14 AM
#700
Battery box on rear bumper for fittings and extra carrier on cargo rack for sewer hose. Pics in the link in my sig. I think I have a total of 40' of hose in the carrier and bumper.
LINK TO MY MODS
