Old 09-06-2016, 08:43 PM   #21
B and B's Avatar
Originally Posted by TURBS View Post
I tow 14k with my 3/4 ton diesel
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "32"
The one we are looking at is 14,800 and we will tow it with a 3/4 ton as well. It is rated at 16k and the Chevy isn't far off the mark.
Old 09-07-2016, 12:27 PM   #22
You will be over the payload of a 2500.
jonwisconsin is offline   Reply With Quote
Old 09-07-2016, 02:48 PM   #23
CaptnJohn's Avatar
Way over ~~~
2016 Keystone Cougar 303RLS
2016 F350 diesel
Edgewater 205 EX 150 Yamaha
Old 09-08-2016, 12:29 AM   #24
bought new 2016 2500hd duramax looking at 295rl sounds like you tow about the same weight Do I need a slider hitch I would like it to be easy to back into tight spots would columbus hit cab without slider hitch. thanks
ss396 is offline   Reply With Quote
Old 09-08-2016, 12:08 PM   #25
Payload rating
What does your Driver Door Sticker say your payload is ?
ksmith954 is offline   Reply With Quote
Old 09-14-2016, 02:28 AM   #26
RPB
I tow a 295RL and you will be disappointed with both the performance and fuel mileage of a 3/4 ton gasser. You will almost surely be over the GVWR on the rear axle too, but might barely squeeze by. I know as I towed mine with a 2010 F350 with a diesel. Your GVWR is 10,000. Your towing capacity means nothing. What means something is the cargo capacity. The pin weight of your fiver will be at least 2000 pounds, probably more. Do yourself and your wallet a favor; buy a 350/3500 diesel. You'll never regret it once you pull you Columbus. I know. I just upgraded to a DRW 3500 RAM as I would've been overweight on the rear axle with the addition of an aux fuel tank, W/D and a gen.
Ron B
2010 Ford F350 6.4L SD CC (srw)
2014 Columbus 295 RL (cream)
RPB is offline   Reply With Quote
Old 09-21-2016, 06:18 PM   #27
I tow a Columbus 320RS with an 11' Ram 2500 Cummins & love it. However if I were buying again I would buy a 3500/350 SRW for the extra bed carrying capacity. It's not the towing capacity but the carrying capacity you need to be concerned with. Good luck.
Wayne & Sheryl
Plus Ollie & Sophie
(they don't know they're dogs)
2011 Ram Laramie 2500 CC 4X4 6.7 Cummins
2015 Columbus 320RS
"Where ever you go, there you are" Buckaroo Banzai
Goukcats is offline   Reply With Quote
Old 12-28-2016, 04:43 AM   #28
Chevy 2500 HD
We pull our 2015 Columbus 320 RS about 11,000 plus with our 2012 gas Chevy 2500 HD 4X4 no issues or strain. The tow rating on ours is well over 14,000. No complaints driving up to Tahoe on highway 50 passing the slower vehicles.
Frank & Kathy
2015 Columbus 320RS
2012 Chevy Silverado 2500 HD
paluka44 is offline   Reply With Quote
Old 12-28-2016, 11:07 AM   #29
You can pull it but you probably were over your payload when you add pin weight, passengers, and camping stuff. Pull it, yes. Safe?????
Old 12-28-2016, 11:33 AM   #30
My 2016 2500HD gasser has a payload of 2906 lbs.
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
295, 500, columbus, gas
