Closed Thread
Old 02-11-2012, 06:53 PM   #161
Thanks for the description Spurge. My strap arrived today. The sofa-side one died within the year, had no joy trying to get a replacement through my dealer (beginning to discover he was a really great guy until we drove off the lot with the trailer. Every problem we have had, and there weren't many, have been extremely well handled by FR direct). SabreSam helped out in getting a replacement to me. I think my 31RETS is back to front compared to yours in that the pin is on the outer side of the slider, and the other end is screwed into the chassis. Now I know what the probable cause is I'll go attack the refit tomorrow, Tx rain permitting.
Wooly
2010 Sabre 31RETS-6
2007 Sierra 2500HD Duramax
Reese 18K Signature Series
wooly is offline
Old 02-15-2012, 05:19 PM   #162
Sabre Sam,
We have a Sabre 32RCTS on order and wanted to have slide toppers installed but they were not listed as a option.
We have a quote from the dealer to install them when delivered, but, based on some posts on this forum, I'm thinking that it might be better or even less exensive if I could have them installed by factory.
Is this possible and, if so, what would the cost be for the 32 RCTS?? Would it delay delivery?
Cathy & Jeff
Midland, Michigan
2013 Sabre 32RCTS / 2012 Ram2500 Hemi
SimchaSabre is offline
Old 02-16-2012, 02:12 PM   #163
Super Lube Bearing System
What exactly is this? What benefit does it provide?
Deleted Account is offline
Old 02-16-2012, 03:57 PM   #164
Here to Help
Originally Posted by SimchaSabre
Sabre Sam,
Please have the dealer that you purchased from contact me through the factory.
SabreSam is offline
Old 02-16-2012, 11:02 PM   #165
I will do that. Thanks.
Cathy & Jeff
Midland, Michigan
Old 02-17-2012, 10:43 AM   #166
I have the 32bhok and was reading up on bearing / axle maintenance. Shows that we have the super lube bearings. Can you give more info on these?
Old 02-17-2012, 11:45 AM   #167
TURBS's Avatar
The super lube bearing system means you can grease your bearings and spindles without taking hubs apart. If you take off the hub cap off your wheel you'll notice a grease zerk there to manually grease your bearings and hubs.
Also known as a bearing buddy more so used on boat trailer axles.
TURBS is offline
Old 02-17-2012, 11:46 AM   #168
H2oski
gpigate take a look at the following link, it has instructions and a diagram. It is off of Lipperts website.
http://www.lci1.com/OwnersManuals/Tr...%20ADD-Web.pdf
Let us know if you need any more info.
Wife
2007 Chevy 2500 HD 6.6
2012 Sabre 31RETS
(LA) Lower Alabama
h20ski is offline
Old 02-17-2012, 11:52 AM   #169
Thanks for the info. That is what I was looking for.
I have been reading up on the RV.net forums about the ez lube system used with dexter axles. People are having major issues with these and have gone back to manually packing the bearings.
Is this case with the super lube? anyone having any issues? recommendations on grease type? Any idea on what was put in from the factory so we can match the grease?
Old 02-17-2012, 12:58 PM   #170
H2oski
gpigate
I have the Lippert axle manual on digits, PM me your email and I'll send it to you.
Wife
2012 Sabre 31RETS
(LA) Lower Alabama
h20ski is offline
Closed Thread
led pad
