Closed Thread
Old 02-21-2012, 09:00 PM   #171
Just joined the forum today. Looked at, considering a Sabre 34REQS. I was wondering 2 things. Why people use the '6' after their model #'s ? Is there a backer in the wall for mounting a small TV over the dresser in the bedroom?
Wiscampsin is offline
Old 02-21-2012, 09:32 PM   #172
amxpress's Avatar
The "6" at the end of the model number indicates the trailer has 6,000# axles which are larger than the standard axles; it's the way to go.
Sorry I can't help you with the TV support question. I'm sure someone will respond.
2013 Palomino Columbus 320RS
2007 Dodge RAM 2500 6.7 Cummins
Reese 15K manual slider
Prodigy
M.I.L. in Florida for good!!
amxpress is offline
Old 02-21-2012, 11:29 PM   #173
westyguy's Avatar
When we bought our new REQS, we were told that the "6" designates a true all metal frame: front, back, 2 sides, top, and bottom. Apparently, some build metal construction but with a wood top.
Harland & Nita from Texas
Rusty & Coffee - Guard Dachshunds
2012 Sabre 34REQS-6
2011 F-250 CC/SB/6.2L Gas/2X
Nights Camped 2012 = 14
westyguy is offline
Old 02-21-2012, 11:34 PM   #174
westyguy's Avatar
Oh and the backer board. Nothing was mentioned about that. They told us the design was to put the TV on the chest of drawers. That's working good for us. We're really enjoying ours.
2012 Sabre 34REQS-6
westyguy is offline
Old 02-22-2012, 06:53 AM   #175
TURBS's Avatar
Was told also the 6 was for the upgraded 6000 lb axles
TURBS is offline
Old 02-22-2012, 09:27 AM   #176
Here to Help
Yes Turbo is right,
the "-6" after the model identifies it was built with the 6000lb axles and 16" wheels with 8 lug wheels. Some of our competitors save money by not upgrading to the 8 lug wheel when they jump to the 16" wheels.
Any other questions, let me know.
SabreSam is offline
Old 02-22-2012, 09:52 AM   #177
Thanks for your helpful replies. The units on the dealer lot all have the 6000 lb axle/16" wheel pkg. They say it's the only way they order them. It seems like a no brainer for the price. I might try building something to get our 19" flat screen above the window if it will fit. DW doesn't like the windows blocked.
One more ?, we're considering the thermopane window upgrade. We currently have a seasonal site in Wisconsin and use our camper from April thru October. It does get a bit chilly in the spring and fall and with all those windows I thought it would help with condensation and keep the units temp more liveable. Thoughts???
We actually went to the dealer to look at another brand, can I say Jayco on this board , because we have one now and are very happy with it. When DW walked into the 34REQS she loved it. That one on the lot has all the options we would want except the thermopane windows so we would have to factory order one.
Old 02-22-2012, 10:45 AM   #178
Does anyoneknow how wide the 16" tires are? I want to build some leveling ramps to have ready when my ne 32 RCTS-6 arives. I have a lot of treated 2X6 lumber available that I could use if that would be wide enough.
Cathy & Jeff
Midland, Michigan
2013 Sabre 32RCTS / 2012 Ram2500 Hemi
SimchaSabre is offline
Old 02-22-2012, 10:53 AM   #179
TURBS's Avatar
2x8 would be better or 2x10 is what I used.
My old tt I could use 2x6 but these 16 inchers are wider.
So I went with the 2x10 its a little more forgiving if your not quite sqaure.
2x6 will not work unless side by side
TURBS is offline
Old 02-22-2012, 12:22 PM   #180
JDWeir's Avatar
SimchaSabre,
I just measured the tread area on my 31RETS with the 16" tires and it measured about 7" across the tread face.
HTH
TV, 2000 Dodge RAM 2500 Quad cab short bed, Cummins 5.9, Edge Comp, Gauges.
5ver, 2011 Palamino Sabre 31 RETS.
JDWeir is offline
Closed Thread
led pad
