Closed Thread
Old 04-10-2012, 12:02 PM   #241
Our new unit came with a manual rewind trap for use in an emergency when there is no shore or batt power available, but we were also told that once you retract a power awning manually, it requres a "qualified service person to "reset" it back to power mode....Not sure what that means though and I have not pursued it.
Cathy & Jeff
Midland, Michigan
2013 Sabre 32RCTS / 2012 Ram2500 Hemi
SimchaSabre is offline
Old 04-10-2012, 12:04 PM   #242
oops...typo....
trap=Strap
Cathy & Jeff
Midland, Michigan
Old 04-10-2012, 01:20 PM   #243
I have a new 31RLTS. The steps leading up to the bedroom have several screws on the treads, but when I remove these screws the treads still wont come off. Are they glued down as well? Is it possible to safely take them off without damaging the treads?
evergryn is offline
Old 04-10-2012, 02:36 PM   #244
TURBS's Avatar
I would guess there glued down.
better question is why are you taking them up?
TURBS is offline
Old 04-10-2012, 02:40 PM   #245
Here to Help
Steps
Dear Customer,
We don't glue them down, but there maybe corner trim that is nailed to the wall and step that is holding it inplace. Look there, if not send me a picture of the step and I will get you some more answers.
SabreSam is offline
Old 04-10-2012, 03:50 PM   #246
Interior Height
What is the interior height of the 2012 32 RLTS travel trailer ? I see the slide room is 6'1".
jiggerk is offline
Old 04-10-2012, 11:04 PM   #247
32 rlts
Is the flip up counter extension standard in the kitchen on these travel trailers ? and with the drawers under the bed does the bed raise up for more storage, and if does not can I add a hinge for that purpose ?
jiggerk is offline
Old 04-11-2012, 11:34 AM   #248
Cable TV Connections
Originally Posted by SabreSam View Post
Jamie S.
The cable signal will go only to the main Living room TV. The bedroom TV(s) only receive Ant/Air signal.
Sabre Sam: Please don't take this wrong. I have a 2011 RETS and the Cable signal input adjacent to the water hookup feeds both living room and bedroom TV's, along with the external connection in the curbside basement access.
SPAT61
spat61 is offline
Old 04-11-2012, 11:40 AM   #249
TURBS's Avatar
But the satellite in only goes to the main living area.
TURBS is offline
Old 04-12-2012, 08:05 AM   #250
Here to Help
The countertop extention is standard. The bed base does not raise.
SabreSam is offline
Closed Thread
led pad
