07-25-2012, 10:34 PM
#541
phat phrog stunt crew
I don't have to keep mashing the switch.
yeah, a callouse could ruin an entire camping trip
07-25-2012, 11:28 PM
#542
Originally Posted by SimchaSabre
I've been thinking about this unit.
07-26-2012, 06:00 AM
#543
Mostly, it frees me up to do other setup/pack-up chores. I love the auto level feature and the auto connect/disconnect works well most of the time and when it is off, it is usually only off a small amount.
It's a pretty in expensive add-on that I think Sabre should just include.
Cathy & Jeff
Midland, Michigan
2020 Cedar Creek 34IK / 2019 Ram3500 CID
07-26-2012, 11:02 AM
#544
Here to Help
Dear SimchaSabre,
Thanks for the input and helping make our product better. I forwarded your suggestion to our PD department.
07-26-2012, 04:53 PM
#545
maybe sabre will retrofit my just purchased 5th wheel at no charge
07-30-2012, 09:32 PM
#546
TV lift
On my 32 RLTS with the rear TV on a switched lift. How does one operate this if the switch fails ? Also how can I gain acess to the TV and cable/Antenna fittings ?
07-30-2012, 09:41 PM
#547
Hmmmm interesting questions.
I have no answer but I bet with a year sabresam can help.
07-31-2012, 01:06 AM
#548
on my 32 rlts with the rear tv on a switched lift. How does one operate this if the switch fails ? Also how can i gain acess to the tv and cable/antenna fittings ?
2013 !!!!
07-31-2012, 07:38 AM
#549
Here to Help
TV Lift
I'm no expert on this lift system. First the wood organizer that sets atop the unit can be lifted off. This should allow you to gain acess to the TV. I beleive you should be able to manual lift the TV vertical. The motor used on your lift does have a brain that should tell you why it's not running. You would have to work through the TV opening to get to your cable/antenna fittings.
07-31-2012, 08:29 AM
#550
Sam
I would like to pull a boat behind my Saber. Would I be able to install a hitch to the tubing that holds the sewer hose or should I add another to the side frame?
By doing this will I void any warranty
2012 Saber
2008 Super Duty
07-31-2012, 08:33 AM
#551
Originally Posted by Goosechase
Sam
Year and model would help.
Anything done to frame will void warranty
Unless authorized by factory.
Ron
07-31-2012, 07:36 PM
#552
Sam,
I'm a new 36QBOK owner and I'm having an issue with warranty work. Couple of questions if you don't mind: How long should it take to get a replacement door assembly for the outdoor kitchen? I recognize the timing will vary but what is a reasonable expectation? Does the factory have to pre-authorize warranty repairs and if so, how long should the authorization take. I've been waiting over two weeks to get a defective slide repaired and the excuse I'm getting from the dealer is tht he is waiting on factory authorization. I'm skeptical. Looking forward to your reply. Thanks for your help.
07-31-2012, 09:02 PM
#553
Here to Help
Sam
Dear customer
First I would not do a "bolt on" to the tube bumper. If you weld to the frame you will void the warranty on the frame. I spoke to a lot of customer in the great lake states that add a boat hitch. If you decide to add one you will want a frame shop to weld it to the I-beam frame. Some underbelly might need to be dropped down to expose the frame.
07-31-2012, 09:04 PM
#554
Here to Help
Originally Posted by jhw
Sam,
Dear customer
If you will send me a PM with your name, vin number and name of your servicing dealership, I will ask the warranty department to look into it.
07-31-2012, 09:30 PM
#555
Buying a Sabre 34tbok this week but have to travel so I have kind of limited communications with with the Salesman.
Question: will a stackable washer and dryer fit in the 34tbok or is my only option the snall washer/dryer combo unit? Thanks in advance for any advice you can give.
07-31-2012, 09:32 PM
#556
Here to Help
Washer / dryer combo only.
08-03-2012, 12:15 PM
#557
Always Learning
Ok, so here's another - we have the upgraded countertops in our 36QBOK. They appear to be a Corian-type of surface. The counter top came with 2 scratches in it and we've unfortunately added a couple ourselves in our first 3 weeks of ownership + use.
My cousin said he worked on Corian countertops for a while and that Scotchbrite was the best plan for removing and then buffing them out. Our dealer wasn't helpful saying that a whole new countertop would need to be ordered to remove the ones that came from the factory -- I think they're just not familiar with sold-surface countertops.
Thoughts?
(And funk-nabbit, I have another question... I'll be darned if I can't remember what it was!)
08-03-2012, 12:31 PM
#558
Welcome to the begining stages of CRS. I am the distributor for NC.
08-03-2012, 12:52 PM
#559
Second A/C
Your answers have all been VERY helpful. Thank you! I love being able to use this forum to get so many different suggestions.
08-03-2012, 02:38 PM
#560
Here to Help
Thoughts?
Dear Customer,
the following website does have information about removing scratches in the countertops.
Consumer Cleaning, Care & Repair
