Closed Thread
Old 04-24-2012, 06:00 AM   #281
SabreSam,
We want to add / modify some lighting in our 32 RCTS and would like the switches to match the ones that we already have in the camper.
Please let me know if these are available through Sabre or if possible, provide a OEM mfg/part number. We will need a few singles and a few doubles.
Cathy & Jeff
Midland, Michigan
2013 Sabre 32RCTS / 2012 Ram2500 Hemi
SimchaSabre is offline
Old 04-24-2012, 06:48 AM   #282
Here to Help
Switches
Originally Posted by SimchaSabre View Post
SabreSam,
Dear Customer,
You will need to purchase the switches from any Sabre dealer. Our factory and our OEM partners don't have a retail license to sell to you directly. I'm sorry but the situation is simuliar to when you need a GM car part.
SabreSam is offline
Old 04-24-2012, 07:30 PM   #283
Regarding my water heater problem, after speaking with the Suburban tech and describing the readings I was getting, it sound like it was going to be the thermostat, which is about the only other component in the loop. He stated I should read continuity from the switch end of the wire all the way to the lead that goes on the element, which I didn't have. Needing the camper for this weekend, and not wanting to mess with a dealer, I decided to dive into it not knowing much about it. I had to remove all of the gas components out of the way to get to where the thermostat should be, and pulled an item that I thought was it. Checked it across the two contacts for continuity which I didn't have. Went to local RV place and got another for $30 bucks, checked it for continuity which it had and installed it, and back in business! Turned out to be a pretty easy fix, but I was just leery of messing with the gas components and a new camper. I've worked alot with electrical, just never with gas. Boy will I make sure there is water in the tank before I fire it up next spring!
2007 GMC 2500 Duramax Classic
2012 Sabre Silhouette 300BHDS
West Texan is offline
Old 04-24-2012, 07:50 PM   #284
TURBS's Avatar
pics of the old one ?
TURBS is offline
Old 04-24-2012, 08:38 PM   #285
I haven't ever posted pics on here before. The old one looked just like new though, externally there wasn't anything at all to indicate that it was bad. I didn't get any pics while everything was taken apart, didn't even think about it.
Old 04-26-2012, 05:33 PM   #286
I need a screen door slide for my 2011 SABRE SILHOUETTE model 260BHS. Where can I get one like the original?
2011 Sabre Silhouette 260BHS
2006 F-250 6.OL
tinkerreknit is online now
Old 04-26-2012, 08:58 PM   #287
2012 34REQS No Propane --Help!!
Just about to head out for the first outing of the season and now I have no Propane anywhere. Checked the bottles and they are full , made sure the goofy bottle switch is in the right position , opened both bottles to be sure and no propane to anywhere. Usually flow to the stove and light it first but nothing.
Help !!!
Coldredneck is offline
Old 04-27-2012, 04:01 AM   #288
Here to Help
Dear Customer,
The factory can not sell parts directly to you. Any Sabre dealer can order the part.
SabreSam is offline
Old 04-27-2012, 06:35 AM   #289
TURBS's Avatar
Help !!!
First are they full?
Second shut both valves and open them real slow.
try that
Ron
TURBS is offline
Old 04-27-2012, 07:52 AM   #290
H2oski
Sounds like you are having the same issue I had when I first bought mine. What I found was that the far tank safety valve (excess flow valve) would close because of an overflow due to the line being empty. (New) To reset the check valve, turn the tank off for at least 10 seconds, then turn it back on very slowly, so the line fills with gas slowly, once the line is pressured up then open it full on. You may have to do this several times. That solved my issue.
Wife
2007 Chevy 2500 HD 6.6
2012 Sabre 31RETS
(LA) Lower Alabama
h20ski is offline
Closed Thread
led pad
