08-10-2012, 06:08 AM
#581
Digital TV Reception Links
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
08-10-2012, 11:52 AM
#582
phat phrog stunt crew
thanks for the links herk. will look into them more
and sam, thanks for the reply. yes, i did rotate antennea towards where i know strong signals originate, and it helped bring in more channels, but the "pixilation"(?) and picture freeze was still present.
will go to storage lot this eve and break out owners manual, but my wife thinks she left it in the cabinet beside the fireplace (which is covered by the slide). not much room next door to move slide out as they dont leave that much room between spaces.
08-10-2012, 11:55 AM
#583
Pixelation and picture freeze is signal related.
Make sure ALL connections are tight.
08-11-2012, 08:16 AM
#584
I would like to forest river put out a manual with some info in it with details about your trailer. Ive went to my manual 4 or 5 times and found nothing to help me. It is the most generic worthless manual Ive seen. it is a waist of trees.
Duchie
08-13-2012, 01:52 AM
#585
Sabre Sam where can I find my TV cable splitter on my unit ? The Awning side outdoors tv jack is fuzzy, tried different cables, ran a cable from bedroom reception perfect, took outside fitting off cable tight.
08-13-2012, 06:50 AM
#586
Behind entertainment center is my guess.
Ron
08-13-2012, 01:33 PM
#587
Here to Help
Normally there is a splitter behind the jack/plate where the booster is.
08-13-2012, 11:06 PM
#588
Need Help Sabre Sam
Well I did it, I closed the bunk slide on our Silhouette 300bhds with the door open and, crunch How can I go about ordering a new bunk door and door handle?
2007 GMC 2500 Duramax Classic
2012 Sabre Silhouette 300BHDS
08-13-2012, 11:44 PM
#589
I have the 2013 32 RLTS. How do you gain access to the area were the Booster box and othe TV connection are ? The cabinetry is all sealed, with no access panel.
08-14-2012, 06:14 AM
#590
Behind your radio/DVD player.
08-14-2012, 06:18 AM
#591
Man that's a bad deal.
In the future make a check list shutting such things as apart of your pre trip close up.
My dw did this once with our outside shower door on our old tt.
Door had a slight interference fit with main slide ....... it was on the list next trip.
Contact your dealer for door.
Sorry bout your door
Ron
08-14-2012, 03:00 PM
#592
I would like to know if I can add the rear cargo rack to the Sabre Silhouette 320fqds? Is the bumper on the Silhouette the same as the upline Sabre?
Gman
08-14-2012, 03:04 PM
#593
Gman
It actually bolts to the frame and when down rests on the bumper.
Ron
08-14-2012, 03:22 PM
#594
Ron
Can I buy the hardware? It looks like there is room. I need to move the spare tire.
Gman
08-14-2012, 03:30 PM
#595
I'm sure Sam will have an answer soon. Here's my $.02.
If there is enough room between your bumper and the coach, I'd try it. There's probably 6" between the rear of the coach and the forward edge of the bumper on my Sabre 31RLDS.
I'd make the hardware instead of buying it. There's not much to it.
If you're interested, send me a pm and I'll take pics of my brackets.
2006 Ram 2500 CTD
2011 Sabre 31RLDS
08-14-2012, 03:34 PM
#596
Can take pics of mine to.
Just two flat plates sandwiched between frame.
08-14-2012, 03:43 PM
#597
Thank you, and F1100turbo,
Photos would be great, if this doesn't work out, I will have to probably have a weld shop reinforce the rear bumper and add a 2" receiver and get the receiver type cargo rack. Thank you for your help
gman
08-14-2012, 05:26 PM
#598
08-14-2012, 09:03 PM
#599
Here to Help
Gman
Dear Customer,
As you can see by Turbo's pictures you might have enough space for the brackets, but if you don't have the extra space on each side like Turbo's pictures show, the rack will hit your rear wall in the up position. You might need to keep the rack down. With it not being factory installed you might not get the full 450 lb rating. You would need to order the rack for a Sabre dealer. I hope that helps
08-14-2012, 09:08 PM
#600
Originally Posted by SabreSam
Dear Customer,
I beleive there is not enough distance between your rear wall the the bumper. You would need to remove your bumper and have it extended out.
As Sam said look at the distance between my bumper and wall
