Closed Thread
Old 05-14-2012, 08:50 PM   #311
TURBS's Avatar
Oh darn I was thinking the landing gear I'm soooo sorry!
TURBS is offline
Old 05-16-2012, 02:47 PM   #312
Originally Posted by f1100turbo View Post
In door of left propane tank d/s
Thanks f1100turbo, It was so obvious I totally missed it. ( Had visions of one day driving home from camping with the bed slide out and two big red flags nailed to the side)
2011 31' RETS Sabre
2007 Dodge Ram 2500 HD
Lovin It
spurge1947 is offline
Old 05-17-2012, 04:40 AM   #313
ret2006's Avatar
I havent had any problems with any of the slides, but I do have a question. On the 31 RETS, does anyone know where the manual slide opening is for the bedroom slide ? Thanks in Advance...
Originally Posted by SabreSam View Post
It's under the queen bed. You must raise the bed and remove the plywood panel. You will then see the motor.
What if the bedroom slide is stuck in the closed position, you can't get into the bedroom of the 31 RETS with the slide in? Would probably have to break through the bedroom window to get in. Any suggestion? Just want to have an idea on what to do in a "worse case scenario". I currently have my 31 RETS at the dealer getting a new converter and trying to see why my bedroom slide is so sluggish lately, going in and out.
2014 Cedar Creek 34 RLSA-7
2015 Chevy Silverado 3500HD LTZ SRW
ret2006 is offline
Old 05-17-2012, 06:28 AM   #314
TURBS's Avatar
If it isn't to late I would suggest the upgrade to a progressive dynamics converter.
Also my bedroom slide had a slight issue as well.
Carpet was getting wound up in the slide mechanism.
TURBS is offline
Old 05-17-2012, 06:54 AM   #315
ret2006's Avatar
They are suppose to be putting in a 70 AMP Progressive Dynamics converter today, suppose to pick it up around noon. Said they couldn't check the slide until the new converter was in and the 12 Volt system 100% charged. The slide just seemed to get more sluggish each time we used it. Could be the carpet, I will bring this to their attention.
ret2006 is offline
Old 05-17-2012, 06:59 AM   #316
TURBS's Avatar
Does yours have stickers stating unit must be plugged into shore power to move slides?
Just an Fyi.
Hope all works well.
Please update!
TURBS is offline
Old 05-17-2012, 08:06 AM   #317
ret2006's Avatar
Just an Fyi.
Please update!
The stickers say "Battery Hookup Required for Slide Operate".
ret2006 is offline
Old 05-17-2012, 08:17 AM   #318
TURBS's Avatar
Huh I think mine says shore I'll double check.
TURBS is offline
Old 05-17-2012, 02:31 PM   #319
Mine says the same.
Wiscampsin is offline
Old 05-18-2012, 11:11 AM   #320
Sir
Whats the deal with these refrigators? Have a 34reqs 2012 and I have owned 2 jaycos and 1 forest river and never have I heard a refrigator make so much noisy. It also takes 18 to 24 hrs to cool down. Why put a 12 volt fan in a refrigarator unless you are trying to cover up a problem. Also I took off vent cover on outside for fan and there was quite abite of moisture which could cause delamanation. I have also got several other problems with the unit. Must of been built on a friday or monday.
Duchie
duchie is offline
Closed Thread
led pad
