Closed Thread
Old 05-21-2012, 08:13 AM   #341
Herk7769's Avatar
Originally Posted by duchie View Post
Missing the point. If it requires a fan then put a quality fan on it that doesnt sound like a electric drill running all night.I spent a week(first time I used it) where it was totaly shaded,Ididnt even put up the awning,temp avg'd 84 degrees and the fan ran 80 to 90 percent of the time.
Duchie
Are you sure it was the fridge? My converter is under the fridge and it has a large fan. My Dometic is pretty quiet.
HAM CALLSIGN - KC3FFW
Herk7769 is offline
Old 05-21-2012, 02:15 PM   #342
Here to Help
Drawer Guide Release
Originally Posted by NeilM108 View Post
SabreSam,
On our new 32 BHOK-6, the top drawer in the Galley won't close. It is on an angle (gap on left side when closed).
I tried to slide the drawer out, but I can't figure out how to release it from the rails.
Useful tidbits like this are conspicuously absent from the owners manual.
Help!
NeilM
Dear NeilM,
The attached picture is a drawer guide that is not mounted on a drawer. Notice the black plastic lever. You should see one of these on each side of the drawer when you have it pulled out. On one side you will need to press this lever down, and on the other side press it up. This should release the drawer. You can then inspect the guides and see what is going on.
Name:	2012-05-21 15.08.38.jpg
SabreSam is offline
Old 05-22-2012, 12:52 PM   #343
Drawer not aligned
SabreSam,
Thanks for the photo. It worked.
I've attached a picture of the drawer looking down. you can see the gap (a little more than 3/8") on the left side.
To me, it looks like the drawer guides are not perpendicular. I'm 400 miles from the selling dealer and 75 miles from the closest Forest River dealer. Is the backplane (that the guides attach to) screwed and glued or just screwed?
Neil
NeilM108 is offline
Old 05-22-2012, 09:24 PM   #344
Re attaching PinBox Cover
SabreSam,
My dealer had to remove the white plastic pinbox cover when they installed a new pin box upgrade on my 32 RCTS. I would like to re-attach it myself, but the mounting holes no long align properly due to the new pin box being shaped slightly different. I can hit one existing screw hole on each side, but I would like to add a couple more on each side. It looks like the self tapping scews go through the plastic and tap into the pin box mounting frame.
Do u think it would be ok to add a couple of "new" holes on each side. I don't want to hit anything nor do I want to weaken anything critical..
Cathy & Jeff
Midland, Michigan
2013 Sabre 32RCTS / 2012 Ram2500 Hemi
SimchaSabre is offline
Old 05-23-2012, 09:48 AM   #345
Here to Help
SabreSam,
Neil
Dear Customer,
the support for the guides is screwed. The guide may have shifted or even cracked. Let me know if I can be more help.
SabreSam is offline
Old 05-23-2012, 09:52 AM   #346
Here to Help
Originally Posted by SimchaSabre View Post
SabreSam,
I don't want to guide you wrong, so I have a question. Are you wanting to drill more holes in the extended king pin or more holes upward (under the king pin, upwards toward bedroom floor)? You should be able to trim the cover if needed.
SabreSam is offline
Old 05-23-2012, 11:20 AM   #347
Originally Posted by SabreSam View Post
Dear Customer,
It is firmly affixed at the wrong spot. Nothing is broken or cracked. I will move it. Thanks for your help.
NeilM
NeilM108 is offline
Old 05-23-2012, 11:57 AM   #348
More holes upward into the bedroom floor. It looks like I'd be drilling through the bracket that the Pin box bolts to.
Cathy & Jeff
Midland, Michigan
Old 05-23-2012, 12:40 PM   #349
Here to Help
You should be fine. Try to use short screws. Predrill holes in the cover if needed. Don't just put a screw through the plastic, predrill a little bigger hole so the cover has a little room to grow in the hot and cold.
SabreSam is offline
Old 05-23-2012, 02:51 PM   #350
I hadn't thought about enlarging the holes in the cover. Thanx SS
Cathy & Jeff
Midland, Michigan
Closed Thread
led pad
