Closed Thread
Old 05-30-2012, 07:14 AM   #371
TURBS's Avatar
Was it hitched right?
Of all the pins I've seen I have never seen different lengths or adjustments within the pin.
TURBS is offline
Old 05-30-2012, 08:19 AM   #372
LGreeves's Avatar
The bad part of the hitching was that I verified that the lock arm positioned correctly but did not look at the saddle for contact. I will get my friction pad and do another hitch up tonight to see if there is a problem for sure.
2013 Palomino Sabre 34TBOK
Pulled with '99 2500 Silverado Ext-Cab
LGreeves is offline
Old 05-30-2012, 09:06 AM   #373
Here to Help
Hitch
Originally Posted by LGreeves View Post
SabreSam,
Got home with new 34TBOK last night and noticed when unhitching the kingpin was riding on the jaws not the plates of the sadle and hitch riding together. I use a B&W companion so my question is the issue with the pin or hitch?
The parts counter had closed before we had finished paperwork so I didn't get my friction pad which will be on the next hitch up, the friction pad will add to the stack up and it looks as though it will be the remedy. So a second question maybe to direct me to a B&W expert(or you if you know) on adjustments there or is there adjustment at the pin?
Dear Customer,
I'm sorry about your problem. Who installed your hitch? I'd start with the installer. There are a lot of customers using B&W hitches. I don't have a contact for B&W, but if you can't get the issue resolved I will try and locate one. If you can, please post a picture of your issue and maybe a member will be able to help.
Let me know if you need me to try and locate a B&W rep.
SabreSam is offline
Old 05-30-2012, 01:10 PM   #374
Originally Posted by ret2006 View Post
I had the same problem with my 2012 31 RETS-6. Cable worked fine using the Satellite connection (it has NO splitters, just a direct cable). There should be a splitter behind the amplifier receptacle which splits the cable signal going into the amplifier and out to the bedroom & basement. Check all the connections, make sure they are tight. I replaced the splitter with another one and it solved my problem. Probably has a couple of splitters on the cable line, hopefully they are where you can get to them and check them. Will look like this.
We replaced the splitter, looks like that was the problem. We won't know for sure until we are in a rv park with cable hookups.
Thanks for the help.
wechoosethislife is offline
Old 05-31-2012, 10:56 AM   #375
Sabre Decal "Touch up"
SabreSam,
I got a little too close to a tree branch last weekend and damanged the burgandy striping decal in a few small spot on the corner of the front cap of our NEW Sabre.
I checked with the dealer and all he can do is replace the entire decal so I'm looking for a less expensive "DYI" fix.
I'm trying to locate something I could use to "touch-up" this up...either some scrap decal that I could use to make a patch out of or maybe a color matched piant pen. Do u have access to anything like that or can u get a paint code that maybe I could match up.
The damaged area is pretty high off the ground and pretty small so I think I can get away with something less that a perfect fix.
Thanx
Cathy & Jeff
Midland, Michigan
2013 Sabre 32RCTS / 2012 Ram2500 Hemi
SimchaSabre is offline
Old 05-31-2012, 02:37 PM   #376
Originally Posted by JDWeir View Post
Jambr403,
As far as the curtain hook goes, one of ours broke as well. I just took both hooks off of that window and used a brown elastic hair tie to keep the curtain bunched. Looks just about like the original and I dont' have to worry about the plastic hook. I can provide a photo if you want. If you decide you still want the hook and can't find one, PM me and I can send you my extra one.
Jim
Thanks for the excellent tip and the offer to send me the hook! I'll try what you have suggested and take both hooks off and use the hair tie. My wife leaves those lying around our house so I'll just snag a couple.
Jambr403 is offline
Old 05-31-2012, 02:38 PM   #377
Originally Posted by SabreSam View Post
Dear Jambr403,
I read your post above. Are you asking me to help you with something or just letting me know what you found?
Thanks Sabre Sam. I think the other forum members have answered all my questions, so no input required on this one! Thanks again for all your help present and past.
Jambr403 is offline
Old 06-01-2012, 11:08 AM   #378
Here to Help
Originally Posted by SimchaSabre View Post
SabreSam,
Thanx
Any chance you can post me picture of the damage. This way I can see which decal you would need. I'm not sure that I would use any type of paint due to the paint being left if you ever remove the decal. Send me a picture and we can see what we can do. It's pretty easy to remove the decal and install a new one. You might be able to do it your self.
SabreSam is offline
Old 06-03-2012, 07:33 AM   #379
AKA KE2DX
Don and Elaine's Avatar
SabreSam, I live in the Lower Hudson Valley area of NY (Fishkill NY) and the closest dealers are either in 2+ hours east or west of us, Why aren't dealers interested in carrying this great line of RV'S? The wife and I love the 34reqs (I saw it at the Rockland RV show in February 2012 without the wife) but she would like to see it in person and both dealers east or west of us dont have this model on their lot ! Any ideas...and can a dealer who does not carry this line order one? Thank you for any help!
2016 Dodge Ram Dually 4X4 Quad cab LB 3500 Cummins 6.7L TD / 2013 Columbus 320rs. Camped 50 days in 2015, 74 days in 2016, 92 days in 2017.
Don and Elaine is offline
Old 06-03-2012, 09:26 AM   #380
SabreSam,
I've attached 2 pics of the damaged decal. I now see that it is only involving one decal so maybe with a little instruction I could replace it my self.
Thanks for the help and thanks for participating in this forum
ID:	14737   Click image for larger version
Cathy & Jeff
Midland, Michigan
Closed Thread
led pad
