Closed Thread
Old 06-27-2012, 06:29 AM   #411
Originally Posted by West Texan View Post
SabreSam,
I need warranty repair to a commode in my Sabre Silhouette which is still under warranty. From what I can tell the broken part cannot be replaced, and the whole commode will have to be replaced. The dealer I bought from is two hours away. I have a local Forest River dealer, but not with Palomino. Local dealer said I will have to pay for the repair, and then submit for reimbursement through the Palomino dealer or through Palomino. Of course I knew the risks of not buying locally, and I can go through the Palomino dealer to have the work done, but I would like to have it done locally if possible. Is there anyway I can get a guarantee through Palomino to get reimbursed, or what are my options? Thanks for any help you can provide.
Let us know how you make out.
NeilM108 is offline
Old 06-27-2012, 09:35 AM   #412
Does anyone know how to access the water pump in the 31RETS (2011). Would like to dampen the sound a bit.
2011 31' RETS Sabre
2007 Dodge Ram 2500 HD
Lovin It
spurge1947 is offline
Old 06-27-2012, 09:40 AM   #413
TURBS's Avatar
Should be readily easy to access in basement on drivers side of 5er behind a panel.
I can see mine through basement door on passenger side and can almost reach in and touch it
TURBS is offline
Old 06-27-2012, 01:14 PM   #414
ret2006's Avatar
The water pump on my 2012 31 RETS-6 is in the basement behind the back wall on the drivers side of trailer, somewhat behind the utilities compartment. You will probably have to take the entire wall down to easily access it or hire a 3 year old to crawl through the small access door. The only way I could see it without crawling through the access door was take my camera and reach over the small partitian covering the water lines from the back of the utility compartment and aim the camera in the direction of the pump. It won't be easy to access the pump without some work.
2014 Cedar Creek 34 RLSA-7
2015 Chevy Silverado 3500HD LTZ SRW
ret2006 is offline
Old 06-28-2012, 02:37 PM   #415
Wow, thanks for the info. I was kinda hoping I could remove one or two stair treads toward bedroom.
2011 31' RETS Sabre
Lovin It
Old 06-28-2012, 05:49 PM   #416
Can the dry weight be determined if...
I were looking at buying a 31CKTS with the following options:
Solid Surface Galley Countertop w/Faucet Upgrade
Free Standing Island w/Solid Surface Countertop
Air Bed Sleeper Sofa
Free Standing Dinette IPO Booth
15.0 BTU A/C IPO 13.5 BTU
12 Gallon Gas/Electric DSI Water Heater IPO 10 Gallon
Ceiling Fan
6000 Lb. Axles w/16 inch E-Rated Tires and Aluminum Rims Standard
Trail Air Equa-Flex Suspension
50 AMP Service
Second 13.5K BTU A/C in Master Bedroom
Upgraded Slide-Out Fascia Throughout
La-Z-Boy Recliner, Cloth IPO Swivel Rocker
Second La-Z-Boy Recliner, Cloth IPO Swivel Rocker
Rear Electric Stabilizer Jacks
Electric Fireplace
Serta Mattress Upgrade
Please advise. Thanks.
mblanks2 is offline
Old 06-28-2012, 09:56 PM   #417
Here to Help
Dear Customer
I'm not sure how you want my help. We do not provide any pricing to customers. All pricing must be provided by a Sabre dealer.
SabreSam is offline
Old 06-28-2012, 11:50 PM   #418
Dry weight
NeilM108 is offline
Old 06-29-2012, 04:41 AM   #419
I'm not asking for pricing. I wanted to know about the dry weight with the listed options.
mblanks2 is offline
Old 06-29-2012, 08:13 AM   #420
Herk7769's Avatar
Dry weight will not change, he is asking about an estimate of the "Unloaded Vehicle Weight" and remaining payload
(The Yellow Sticker Weight).
HAM CALLSIGN - KC3FFW
Herk7769 is offline
Closed Thread
led pad
