Closed Thread
Old 06-29-2012, 02:08 PM   #421
Here to Help
Originally Posted by mblanks2
I'm not asking for pricing. I wanted to know about the dry weight with the listed options.
Dear customer
I will have an answer next week. I will find a vin number of a unit with those options and see what it weight.
SabreSam is offline
Old 06-29-2012, 06:48 PM   #422
Thanks!
mblanks2 is offline
Old 06-29-2012, 10:21 PM   #423
heya everyone
I am from Alberta Canada, buying my new Sabre Silhouette 320 FQDS, from All Star RV in sherwood Park, the lady I talked to about warranty says she's never heard about your factory second year warranty, is this warranty still available? Can us in Canada get in on this program? and would I bring my 5th wheel back to the dealer for warranty work?, thanks for your time and info on this, time is of the essence because we pick it up next thursday (july 5th) and would really like to have this knowledge before I pick it up
Randy
RVarcher is offline
Old 06-29-2012, 10:24 PM   #424
TURBS's Avatar
Yes randy you can get second year warranty through forest river.
Welcome to the forum and congrats on the new unit!
TURBS is offline
Old 06-30-2012, 10:23 AM   #425
New Sabre question
Took our 2012 31R3TS 5th wheel on maiden voyage last week for 5 days, before we head out for a 6-8 wk jaunt. Everything was pretty good except for a few bugs.
  1. We have a sattelite Winegard carryout for DirecTV that we set up and couldn't get it to work when plugging box into TV directly and line into the wall through the RV sattelite hook in built into the RV. Had to run it through the window instead to get it to work with the box directly to the sattelite. Since it's new I would think it should work through the RV. Is there a trick we are missing? Am an avid reader of instructions and couldn't figure it out without direct plug into our box.
  2. Put out the bedroom slide and noticed light coming thru the bottom left of the bed as the rubber has a gap and it seems isn't long enough on that side. Might be a problem if we get wet, nasty weather, or buggy area. Any suggestions?
  3. When the dining side slide goes out there is a step up that trips us in front of the entertainment center. It doesn't lie flat to the floor as the other side does.
  4. The fan on the fridge is quite loud, not sure we can get used to that either.
Bought at Tom Raper RV in Fairfield OH this spring. Took it back already for some fixes before we took it on the road. They suggested we use it for a while then bring it back in the fall to have all fixed at once. Any suggestions would be welcome.
Picture attached
Diane
dianizon is offline
Old 06-30-2012, 12:25 PM   #426
Refrig. fan noisy, had it with mine also. After 3 months of arguing with dealer convinced him to get with ref. vendor and they sent a new fan and it is 80% quieter then original. Alot of people are having the same problem. F.R needs to address the problem.
Duchie
duchie is offline
Old 06-30-2012, 01:21 PM   #427
Here to Help
Originally Posted by RVarcher
heya everyone
Randy
Dear Customer
Please have the dealer contact the Sabre warranty department for the 2nd year form. You will then complete the form and cut a check to Forest River. You will need to do this during your delivery. If the dealer does not understand, please send me a PM with your contact info.
SabreSam is offline
Old 06-30-2012, 01:38 PM   #428
Here to Help
[*]We have a sattelite Winegard carryout for DirecTV that we set up and couldn't get it to work when plugging box into TV directly and line into the wall through the RV sattelite hook in built into the RV. Had to run it through the window instead to get it to work with the box directly to the sattelite. Since it's new I would think it should work through the RV. Is there a trick we are missing? Am an avid reader of instructions and couldn't figure it out without direct plug into our box.[*]Put out the bedroom slide and noticed light coming thru the bottom left of the bed as the rubber has a gap and it seems isn't long enough on that side. Might be a problem if we get wet, nasty weather, or buggy area. Any suggestions?[*]When the dining side slide goes out there is a step up that trips us in front of the entertainment center. It doesn't lie flat to the floor as the other side does.[*]The fan on the fridge is quite loud, not sure we can get used to that either.
Picture attached
Diane
Dear customer
Thanks for being a Sabre owner. Audio and video continues to get more complicated. I would like to call and discuss how you are hooking it up. I also hope other members post how they have successfully got theirs to work. Please send me a PM with a contact number.
A picture of the area showing light would also help.
As the member posted before me, I'm confident Dometic can get the fan issue resolved.
All three of these items can be handled under Sabre warranty. So please contact the dealer to have them addressed.
SabreSam is offline
Old 06-30-2012, 01:51 PM   #429
Herk7769's Avatar
Duchie
Duchie,
So, is your problem with:
1) your dealer (who refused to even address the issue)
2) Dometic who, as soon as they were notified you were not happy with the fan in the unit; shipped you a repair part that satisfied you.
or
3) FR who was not (except for your posts here) been notified there was a problem with your camper's fridge?
You need to let this rest I am thinking.
Dometic's customer support sounds first rate here and I am thinking the OP should give them a call or drop them an email.
Contact - Dometic
HAM CALLSIGN - KC3FFW
Herk7769 is online now
Old 07-03-2012, 09:30 AM   #430
Here to Help
Originally Posted by mblanks2 View Post
I were looking at buying a 31CKTS with the following options:
Solid Surface Galley Countertop w/Faucet Upgrade
Free Standing Island w/Solid Surface Countertop
Air Bed Sleeper Sofa
Free Standing Dinette IPO Booth
15.0 BTU A/C IPO 13.5 BTU
12 Gallon Gas/Electric DSI Water Heater IPO 10 Gallon
Ceiling Fan
6000 Lb. Axles w/16 inch E-Rated Tires and Aluminum Rims Standard
Trail Air Equa-Flex Suspension
50 AMP Service
Second 13.5K BTU A/C in Master Bedroom
Upgraded Slide-Out Fascia Throughout
La-Z-Boy Recliner, Cloth IPO Swivel Rocker
Second La-Z-Boy Recliner, Cloth IPO Swivel Rocker
Rear Electric Stabilizer Jacks
Electric Fireplace
Serta Mattress Upgrade
Please advise. Thanks.
Dear Customer,
I found a unit that left the plant with the weight of 10,164. This unit had all the specs but not the second AC. So I'm guess that would add approx. 120 lbs. Let me know if I can be of any addtional help.
SabreSam is offline
Closed Thread
led pad
