Closed Thread
Old 07-11-2012, 12:21 PM   #471
H2oski
There was an anode rod in mine.
Wife
2007 Chevy 2500 HD 6.6
2012 Sabre 31RETS
(LA) Lower Alabama
h20ski is offline
Old 07-11-2012, 12:47 PM   #472
There's one in our 2013 too.
Wiscampsin is offline
Old 07-11-2012, 12:50 PM   #473
TURBS's Avatar
all sabre rv's come with a suburban water heater and all are equipped with an anode rods.
Suburbans are ceramic lined such as a residential unit. And require an anode rod
Atwoods are aluminium lined and do not require an anode rod since the tanks become the rod.
TURBS is offline
Old 07-11-2012, 12:53 PM   #474
thank you
Duchie
duchie is offline
Old 07-12-2012, 02:30 PM   #475
Here to Help
TV
Originally Posted by jiggerk View Post
Thanx Sabre Sam, Is the whole wall from the window to the closet, strong enough for this mount or only the area in the corner ?
No. there are some areas that are mainly block foam.
SabreSam is offline
Old 07-12-2012, 07:24 PM   #476
MaD
Any one know where i can find the fuse for the rear electric stabilizer jacks on a 2013 Sabre 34tbok?
MaD is offline
Old 07-12-2012, 08:18 PM   #477
TURBS's Avatar
Up by the battery
TURBS is offline
Old 07-12-2012, 08:20 PM   #478
MaD
Thanks. I checked that one and it's good.
MaD is offline
Old 07-12-2012, 08:22 PM   #479
TURBS's Avatar
Its a circuit breaker not a fuse.
There should be two of them side by side. Right behind battery.
TURBS is offline
Old 07-12-2012, 08:23 PM   #480
MaD
I'll check again. tks
MaD is offline
Closed Thread
led pad
