Closed Thread
Old 07-23-2012, 10:53 PM   #521
Another question... for the bunk house slide on the side opposite to the outdoor kitchen, is it normal to feel a 1" - 1 1/2" step-up into on the floor when it's fully extended? The slide didn't "sink down" like the other slides did. I think it's normal because the slide works differently than the other 2, but I thought I'd ask.
Yes I would like to know also. Our Dinette slide is the same way ?
jiggerk is offline
Old 07-24-2012, 08:46 AM   #522
Originally Posted by jsk View Post
Can you tell me what the stain color is for the cabinets? I am going to build a cabinet door and stain it to match the surrounding cabinets so we can stop the draft. When we use the furnace cold air comes in when it is not running. We would like to stop the draft. Thanks for the help and any suggestions.
I wanted to keep it simple so I cut a piece of Reflectix to fit the opening tightly. DW covered it with black fabric for looks.
Wiscampsin is offline
Old 07-24-2012, 09:03 AM   #523
TURBS's Avatar
Pic of what your doing?
I'm not sure I understand where this said draft is coming from.
I do know where the cold air return is but not sure how there's a draft there.
TURBS is offline
Old 07-24-2012, 07:11 PM   #524
Here to Help
Dear customer
The stain color is hand mixed by the cabinet door vendor. And they are unable to ship stain to customer. I'm very sorry I can't be much help.
SabreSam is offline
Old 07-24-2012, 07:49 PM   #525
Here to Help
Dear customer
I'm going to give you a long winded answer to help explain. On your model we have to utilize a slide system in the bunkroom that does not drop down completely flush. This is due to the holding tank locations between the frame rails for the 1/2 bath and ext. kitchen sink. The tank locations don't allow us to use a "through frame" slide system. The lip you mentioned is seen when you build this model with an air bed sofa. When it's built with the standard bunks the lip is hidden. Moving the air bed to the edge of this lip will help you to not trip over it. I hope this explains something's. I'm sorry it causes you problems.
SabreSam is offline
Old 07-24-2012, 07:50 PM   #526
phat phrog stunt crew
just purchased a sabre 31rets-6 this past sat and so far we love it despite not using it just yet.
is there any remedy to speed up the electric jacks short of converting to hydraulics? my neighboors wildcat is zip..boom..done, while mine takes forever. am i overlooking something? is there a hi/lo switch that wasnt explained to me or i overlooked? my old tt landing gear was faster with an impact drill and a socket.
dwaynerz is offline
Old 07-24-2012, 07:52 PM   #527
Here to Help
Your 32rlts does not use the same slide as the other customer is asking. I suggest that you have a dealer inspect your unit to see if something is unusual.
SabreSam is offline
Old 07-24-2012, 07:53 PM   #528
TURBS's Avatar
Fast is not always a good thing.
Yours are just gear reducted more allowing for more torque.
TURBS is offline
Old 07-24-2012, 07:59 PM   #529
jsk
Originally Posted by SabreSam View Post
Dear customer
That is ok. Thanks for the reply and your time.
2012 F-350 SRW 6.7
2012 Sabre 34-REQS
jsk is offline
Old 07-24-2012, 08:02 PM   #530
jsk
Can you post or pm a pic.? Thanks
2012 F-350 SRW 6.7
2012 Sabre 34-REQS
jsk is offline
Closed Thread
led pad
