Closed Thread
Old 07-25-2012, 10:34 PM   #541
phat phrog stunt crew
I don't have to keep mashing the switch.
yeah, a callouse could ruin an entire camping trip
dwaynerz is offline
Old 07-25-2012, 11:28 PM   #542
TURBS's Avatar
Originally Posted by SimchaSabre
Dwaynertz,
I too was diappointed at first with the landing gear retract speed, but then I installed the "Intellijack Automatic 5th Wheel RV Leveling System"
It doesn't travel any faster, but at least I don't have to keep mashing the switch.
I've been thinking about this unit.
TURBS is offline
Old 07-26-2012, 06:00 AM   #543
Mostly, it frees me up to do other setup/pack-up chores. I love the auto level feature and the auto connect/disconnect works well most of the time and when it is off, it is usually only off a small amount.
It's a pretty in expensive add-on that I think Sabre should just include.
Cathy & Jeff
Midland, Michigan
2013 Sabre 32RCTS / 2012 Ram2500 Hemi
SimchaSabre is offline
Old 07-26-2012, 11:02 AM   #544
Here to Help
Originally Posted by SimchaSabre View Post
Dwaynertz,
Dear SimchaSabre,
Thanks for the input and helping make our product better. I forwarded your suggestion to our PD department.
SabreSam is offline
Old 07-26-2012, 04:53 PM   #545
maybe sabre will retrofit my just purchased 5th wheel at no charge
dwaynerz is offline
Old 07-30-2012, 09:32 PM   #546
TV lift
On my 32 RLTS with the rear TV on a switched lift. How does one operate this if the switch fails ? Also how can I gain acess to the TV and cable/Antenna fittings ?
jiggerk is offline
Old 07-30-2012, 09:41 PM   #547
TURBS's Avatar
Hmmmm interesting questions.
I have no answer but I bet with a year sabresam can help.
TURBS is offline
Old 07-31-2012, 01:06 AM   #548
Originally Posted by jiggerk View Post
on my 32 rlts with the rear tv on a switched lift. How does one operate this if the switch fails ? Also how can i gain acess to the tv and cable/antenna fittings ?
2013 !!!!
jiggerk is offline
Old 07-31-2012, 07:38 AM   #549
Here to Help
TV Lift
I'm no expert on this lift system. First the wood organizer that sets atop the unit can be lifted off. This should allow you to gain acess to the TV. I beleive you should be able to manual lift the TV vertical. The motor used on your lift does have a brain that should tell you why it's not running. You would have to work through the TV opening to get to your cable/antenna fittings.
SabreSam is offline
Old 07-31-2012, 08:29 AM   #550
Sam
I would like to pull a boat behind my Saber. Would I be able to install a hitch to the tubing that holds the sewer hose or should I add another to the side frame?
By doing this will I void any warranty
2012 Saber
2008 Super Duty
Goosechase is offline
Closed Thread
led pad
