Closed Thread
Old 09-19-2011, 11:22 PM   #61
TURBS's Avatar
Most of them are aluminum construction but they vary from model to model.
same thing goes for insulation they all very for r value depending on model.
they very from 20 foot to 36 foot
tt or 5er .
sabre does not make an ultralite unit
TURBS is offline
Old 09-19-2011, 11:36 PM   #62
TURBS's Avatar
is this what your looking for ?
Sidewall Construction (R-9)
• Gel-Coated Fiberglass
• 1/8" Lauan Backer
• 2nd1/8"LauanBackerwithStaggered Seams
• Welded Aluminum Wall Studs (All Openings Framed in Aluminum Tubing)
• High Density Solid Block Foam Insulation • 1/8" Interior Decorative BoardRoof Construction (R-14)
• Vented Attic
• One-Piece EPDM Rubber Roof with 12 Year Warranty
• 3/8" Roof Decking • EcoBatt Glasswool Insulation • Aluminum Wrapped AC Duct • 4-1/4" Tapered Aluminum Roof Trusses • 1/8" Decorative Ceiling Board
Floor Construction (R-14)
• 5/8" Seamless Floor Decking with 25 Year Warranty
• Welded Aluminum Floor
• Large-Capacity Heat Duct Plenum
• DARCO Wrapped Main Floor Moisture Barrier
• Tanks Wrapped in Heat Reflective Insulation
• Corrugated,PunctureResistant Underbelly
TURBS is offline
Old 09-20-2011, 03:19 AM   #63
Great Thanx, After some searching I found it. Now what about the Trailer Frame and axles ?
jiggerk is offline
Old 09-20-2011, 06:59 AM   #64
TURBS's Avatar
The frame is steel and is a fabricated I beam.
Suspensions and axles very with camper size.
My old forest river tt had torsion axles.
my new 5er has 6k axles that are mounted with leaf spring and coupled with a trail air equal flex suspension system. Again varies by model
TURBS is offline
Old 09-22-2011, 06:08 PM   #65
amxpress's Avatar
http://palominorv.com/Brochures/2011...rebrochure.pdf
Check out page 15.
2013 Palomino Columbus 320RS
2007 Dodge RAM 2500 6.7 Cummins
Reese 15K manual slider
Prodigy
M.I.L. in Florida for good!!
amxpress is offline
Old 09-27-2011, 03:52 AM   #66
Sabre 32 RLTS
When will the new 3 slide 32 RLTS travel trailer be advertised ?
jiggerk is offline
Old 09-27-2011, 05:50 AM   #67
Here to Help
What information do you need on this model? It's currently in production.
SabreSam is offline
Old 09-27-2011, 12:36 PM   #68
Floorplan,Photos ?
jiggerk is offline
Old 09-27-2011, 12:58 PM   #69
Here to Help
This is my first try to attach a picture. I hope it works.
SabreSam is offline
Old 09-27-2011, 12:59 PM   #70
Here to Help
didn't work.
SabreSam is offline
Closed Thread
led pad
