07-17-2012, 08:24 AM
#501
Always Learning
Originally Posted by SabreSam
I beleive the following TV bracket part number will work: 30I26514A. You will need to contact a Sabre dealer for a price. The bracket is a flat mount bracket that does not swivel. If you want something that swivels I will need to get you another part number. With the viewable angle of the new TVs, a lot of customers don't want the swing arm brackets because they can sag after time. I hope this helps.
I don't think we need the swivels on the front TV, but I know my daughter is already having us turn the TV in the bunkhouse depending on which side she's sitting on. If you wouldn't mind finding the swivel bracket, it may be what we're after.
07-17-2012, 09:13 AM
#502
Originally Posted by f1100turbo
My unit is in the lower holes in affect raising up the unit.
Dear Customer,
yes those shackle adjustments are used to raise the fifth wheel. You shouldn't need to replace the center hardware.
Please be very careful raising your fifth wheel. I've heard stories of customers flipping over their unit by only raising one side of the trailer too much. Good luck!
Thanks fellas, I'll give it a try.
2007 GMC 3500 CCLB 6.6 Duramax
2012 Sabre 320 FQDS
07-17-2012, 10:07 AM
#503
Here to Help
Swivel bracket used in the livingroom is part #30I46430A
07-18-2012, 10:27 AM
#504
Always Learning
Another question on the 36QBOK.. it has 2 black water tanks. One in front and one in the back. In the control center, there is a hose port for the black tank flush - is this only for one of the black tanks? Is there a way to flush the 2nd blank tank (short of filling it via the 1/2 bath toilet)?
07-18-2012, 10:42 AM
#505
Are you sure it has 2 black tanks ? im not doubting but
web site only shows 42 gallon black tank capacity (1 tank)
126 gray tank capacity (3 tanks)
http://www.palominorv.com/ProductInf...4658&RVType=FW
07-18-2012, 11:38 AM
#506
Always Learning
I heard what you're saying and no - I'm not 100% sure, but I'm pretty positive. Their are 2 handles outside labeled "Waste Water". And inside, I have 2 separate indicators on my panel for Blk 1 and Blk 2 that showed different measurements (2/3 full and 1/3 full).
07-18-2012, 11:56 AM
#507
My panel also is labeled 2 black tanks and have 2 labels on the exterior as well that are labeled waste water.
My tanks from front to rear are as followed.
Tank 1 fresh water
Tank 2 gray water (bath sink & shower
Tank 3 black (toilet)
Tank 4 gray (kitchen sink)
Tank 5 gray (outside kitchen sink)
Now it is possible that your outside sink and rear toilet are tide together.
Hopefully Sabre Sam can clarify your units configuration.
Ron
07-18-2012, 01:01 PM
#508
Always Learning
I don't know the actual tanks/order, but label-wise/handles - I have:
gray 1
wastewater 1
gray 2
[living room/dinette slide]
wastewater 2
gray 3
But, I can't see inside of the under belly to know about actual tanks.
Agreed - I'm sure Sabre Sam will jump in when he has a moment.
07-18-2012, 01:39 PM
#509
Here to Help
36QBOK Tank question
Dear customer,
Great question. Due to your model having a 1/2 bath, you have an addtional black tank that also collects the waste from the 1/2 bath sink and 1/2 bath toilet. You are correct this black tank does not have a flush on it. I hope that clears up any confusion.
07-18-2012, 01:51 PM
#510
Here to Help
36QBOK Tank List
gray 1
wastewater 1
gray 2
wastewater 2
gray 3
A 36QBOK has the following tanks:
1.Master Bathroom Black (with flush)
2.Master Bathroom Grey
3.Kitchen Grey
4.1/2 Bath Black & Grey Combined
5.Outside Kitchen Sink Grey Tank
07-18-2012, 01:59 PM
#511
Always Learning
Sabre Sam - I can't thank you enough for all of your support + help! It is GREATLY appreciated. If you can pass on the word to the web site folks, I wonder if the specs are incorrect for this model on the website.
One more question.. the buttons for the slides for the bunkhouse are right beside of the bunkhouse door. I'm really concerned that my kids (or more so - their friends) are going to push them because they either think they're light switches or they're little bastards... is there anyway to disable these once we're at camp and setup? Something like a cut off switch somewhere.
07-18-2012, 02:12 PM
#512
3.Kitchen Grey
Sam although I know your correct but somethings amiss.
That means he has 5 tanks?
Plus a fresh?
07-18-2012, 02:14 PM
#513
I would think about a slideout disconnect switch as suggested.
07-18-2012, 02:37 PM
#514
Here to Help
Yes I will get on the website department. I can't really help you with the bypass. I'm sure someone with electrical knowledge could add a switch to bypass the switch.
07-18-2012, 03:34 PM
#515
Sam did you overlook my question?
07-18-2012, 03:50 PM
#516
Here to Help
Plus a fresh?
Yep and he lists five handles to dump.
07-18-2012, 05:35 PM
#517
Appreciate all the info in these posts as we're planning to pick up our 36QBOK on July 27th. It's pretty obvious that the dealers didn't cover all this info during the PDI. For newbies like us, this is a little scary.
07-20-2012, 08:48 AM
#518
Always Learning
Another question... for the bunk house slide on the side opposite to the outdoor kitchen, is it normal to feel a 1" - 1 1/2" step-up into on the floor when it's fully extended? The slide didn't "sink down" like the other slides did. I think it's normal because the slide works differently than the other 2, but I thought I'd ask.
07-23-2012, 04:53 PM
#519
This is the cold air return for the furnace. Yes you could cover it in the summer. Does your unit have a second ac?
Can you tell me what the stain color is for the cabinets? I am going to build a cabinet door and stain it to match the surrounding cabinets so we can stop the draft. When we use the furnace cold air comes in when it is not running. We would like to stop the draft. Thanks for the help and any suggestions.
2012 F-350 SRW 6.7
2012 Sabre 34-REQS
07-23-2012, 05:58 PM
#520
Why not make a metal slide that fits behind the present vent that you can slide that closes it rather than having to have a door open that would be somewhat of a safety hazard?
