Old 06-26-2015, 06:00 AM   #1
Awning "scare" lights
Last weekend, our awning lights (they are in the awning tube) stuck to the awning as it unrolled and caused half of the lights to no longer work. I figure that this probably isn't covered under warranty and was wondering where I could find a replacement light strip. I searched on camping world and didn't see any that slide into the tube. Click image for larger version
Name:	ImageUploadedByForest River Forums1435316443.382891.jpg
carinrvt1 is offline   Reply With Quote
Old 06-26-2015, 06:16 AM   #2
Witch Doctor's Avatar
If you still have a warranty, I don't see why it wouldn't be. That's not a so called maintenance item. I would atleast call the dealer first.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 06-26-2015, 12:52 PM   #3
Ours had burnt out "bulbs" when we bought it new, and replacement was covered under warranty. Agree with gljurczyk - get it fixed under warranty.
Now a couple of questions:
1. Is that a Solaire TT in your post? If so, what model? We have a 269bhdsk and love it.
2. Any idea why the strip came out and/or what should be done to prevent a repeat? Reason I ask is that in the last bit of unrolling of our awning, the awning material is someties "stuck" to the awning tube. Never came close to ripping or pulling the light strip out, but I could see how it could happen if conditions were right.
Purduepete
Brian, Stacy, and the girls (11 and 8)
2011 F-250 CCSB 6.7L PSD 4WD
2013 Solaire 269BHDSK
ProPride Hitch
purduepete97 is online now   Reply With Quote
Old 06-26-2015, 01:07 PM   #4
billt01's Avatar
Swapping out Awning LED strip with after market strip
Our solution....
"Camping invloves a tent, bugs, and incliment weather. This aint camping"
-Bill Thomas
Palomino Solaire 317 BHSK
billt01 is offline   Reply With Quote
Old 06-26-2015, 01:07 PM   #5
Flybob's Avatar
Unless there is a safety mechanism to prevent accidentally turning the lights on when the awning is rolled up, this may happen again. Eben though they are LEDs they do generate heat. If the awning was rolled up and the LEDs were turned on, you would not notice it and they would heat up enough to allow them to separate from the backing and possibly damage the awning. You might want to consider putting them on the TT just under the awning. Lots of choices here.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-26-2015, 01:08 PM   #6
It is a (2015) they bought it New,should be a Warr.item! Youroo!!
youroo is online now   Reply With Quote
Old 06-26-2015, 01:12 PM   #7
billt01's Avatar
I see you have the same type awning that I have..
Not to hijack the thread..
BUT ALWAYS.ALWAYS..ALWAYS
tilt the awning so the water will drain off...
I was told this camper had the automatic dump feature that some new campers have...
it does not...see below..
Awning Arm failure
-Bill Thomas
Old 06-26-2015, 01:15 PM   #8
billt01's Avatar
These lights are LED...VERY low level of heat..
my guess is the Vinyl headed up and caused the lights to stick to the vinyl, I have noticed that it does seem "sticky" sometimes...
-Bill Thomas
Old 06-26-2015, 01:19 PM   #9
Flybob's Avatar
It is a general misconception that LEDs do not generate heat. They do generate heat especially the brighter ones and in a space where the heat can not dissipate they will get hot. A quick search will show some that have melted the plastic dome on interior lights.
TST Tire Monitors
2 100W solar panels
Old 06-26-2015, 01:25 PM   #10
billt01's Avatar
I do not disagree, I just know that LED's between 2,500 and 6,000k only put out about 3.4 british thermal units as opposed to 85 BTU's from a 12V incandescent bulb. I have a Palomino Solaire as well, just speaking from experience from the same type of awning set up.
-Bill Thomas
awning, light
