03-21-2015, 12:45 PM
Back Slide on 36QBOK
03-21-2015, 12:58 PM
Yep, that's what it's for is to protect the floor when extending/retracting. You could place a piece of carpeting in that same area to protect the floor until you get it to a dealer for replacement.
Dave
03-21-2015, 02:04 PM
Can you describe exactly where or how to place the carpet and keep it in place?
03-21-2015, 02:12 PM
That plastic piece is on each end of the slide room. Place a piece of carpeting at the end of the slide room that's missing...chances are it may not touch it anyway. If it does, have someone stand on the end of it to keep it from moving. If that area is carpeted, I'd suggest that you use a piece of 1/4 panelling (or similar) to protect the carpeting from snags, damage.
Dave
03-21-2015, 03:16 PM
Always Learning
Do you have similar pictures of the other side?
03-21-2015, 03:50 PM
Dave
Yup, my old Sabre did the same thing and I had it fixed under warranty. Like Dave said, that piece helps protect flooring as the slide comes in. I think placing a think piece of paneling under it as it comes in would be fine. I used my slides without it, but had vinyl flooring and has no problems.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
03-22-2015, 06:56 AM
Mine has the vinyl flooring in the rear bunk house. If I can slide it I and out 3 more times without damage I'll be good the. I can take it in for repair. I'm heading out for Disney World Thursday so I don't have time to take it I for repair prior to leaving.
03-22-2015, 12:54 PM
This is the other side of the slide.
03-22-2015, 01:26 PM
Thats to protect the bottom of the slide, not your carpet or lino. If you take the piece off thats hanging there be sure to get it all off so it dont catch on anything and do damage.
Your unit is a 2014, may want to upgrade that strip to a better product or wear strip, yours looks flimsy
Would also recommend a product called slide slickers. I also used pieces of Formica before I got the slickers.
Here's a thread referencing the use of the plastic strip and what they are to protect. http://www.forestriverforums.com/for...ing-45789.html
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
Seasonal
Zelda the campin dog
