11-11-2017, 01:33 PM
Backup camera not connecting. Elite Entertainment
We have a 2015 Columbus Compass 375 RLC that came from Fun Town. It came with an Elite Entertainment backup camera that has never really worked. I have turned on the lights to on mode, not auto, have read the terrible manual and followed all of the directions, and still no signal. Any suggestions??
11-11-2017, 01:40 PM
Is it wired into the lights, some we're wired into a switch under the rear. Cabinets. The Elite camera system sucks!!
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 59, 2020 0,
2021 4 reserved
11-11-2017, 01:44 PM
I have no idea if it does. Fun Town has been no help on this. I appreciate your input.
11-11-2017, 01:47 PM
Let me ask our Columbus group on FB
Scott & Vicki
2021 4 reserved
11-11-2017, 01:55 PM
I just asked, if I get a response Ill post it here for you
Scott & Vicki
2021 4 reserved
11-11-2017, 02:48 PM
Got 1 response so far, he said you need to power the monitor on first, then turn on the lights. I do not think he is very happy with the Elite
Scott & Vicki
2021 4 reserved
11-11-2017, 04:21 PM
Thank you so much. I have tried power on, turning it off and back on, and nothing. I really appreciate your efforts though!
11-11-2017, 05:25 PM
Got another reply ..,....I had the Elite that didn't work from day one, was replaced at the rally so I took the defective one apart and it had water in it plus the antenna wire wasn't connected to the circuit board
Scott & Vicki
2021 4 reserved
11-11-2017, 05:32 PM
Looks like we need to replace it.
11-11-2017, 05:35 PM
I would, just from my experience that I have seen the Elite Brand is garbage. I do not like bad mouthing a product, but have seen way too many complaints about the Elite
Scott & Vicki
2021 4 reserved
11-12-2017, 01:17 PM
on my MH, it does not work sometimes. "no signal" think the rg6 cable is kinked where the camera in mounted. the builders push the extra cable down the wall and probably kinked it. I will get out a ladder and remove the camera and check it. rg6 cable cannot be bent too sharply.
11-12-2017, 10:39 PM
It will not work if headlights are set to auto... turn headlights to the manual position.
12-12-2017, 12:07 PM
I saw one other Columbus that had the same problem. Found the wire from the light to the camera had a fuse on it that was blown. We had to pull a lot of wire out to find it. But if you try it be careful because as you know the wiring is always the same on all units...!!! (Could be a short wire on yours.)
Okie
Okie
Retired USMC&FAA
2015 Columbus 381FL
08 F450
12-26-2017, 11:24 AM
I have a Columbus 320RS, it had the Elite system on it which didn't work. I contacted Elite which sent me a replacement system which didn't work. I then replaced it with a Voyager observation system which would also loose signal. Their fix is to move the antenna to the side of the trailer, I did one better and made a 50 foot coax cable and routed it under the trailer to the front storage compartment and mounted the antenna there. The signal now is at 4 bars now and never looses signal. Sometimes you have to take things into your own hands.
