Old 01-11-2018, 12:02 PM   #1
Bad Decals
So I have a 2014 Forest River Palomino 32RCTS. Love the rig but the front decal is totally oxidized and cracking. Every few months I take a plastic scrapper and scrape off the loose stuff. It looks like crap. The decal is in two parts and the upper is the one I am really having trouble with. I would like to take both the upper and lower portion completely off and just leave it painted or even repaint the front if it looks bad. I have heard of taking a hair dryer but don't think that will work on the cracking decals. Is there any "remover" I might use or any other recommendations will be appreciated.
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
Davidceder is offline   Reply With Quote
Old 01-11-2018, 12:17 PM   #2
Trying to upload picture
Hopefully I can get this photo to upload
Old 01-12-2018, 11:51 AM   #3
Not much Action here
So; Not any takers on this? I guess it not something everyone does. In lew of any response so far can anyone tell me if the decals are usually Vinyl and if the end caps are gel coated over the paint? I found this product
GraphXOff Vinyl, Adhesive and Paint Remover - GROG
The manufacturer states it is safe if the end cap is gel coated and the youtube videos confirm that statement.
Old 01-12-2018, 12:22 PM   #4
Google "Whizzy Wheel"
That's what I used to remove cracked decals on my Sunseeker
Phil
PhilG is offline   Reply With Quote
Old 01-12-2018, 12:22 PM   #5
I have always had luck with a hairdryer or heatgun. If you use heatgun DON’T hold close or in one spot too long and use low setting only. Time and patience will remove your decals. Then buff and wax paint.
Decon Blue is offline   Reply With Quote
Old 01-12-2018, 12:29 PM   #6
The top decal is SO bad it is in thousands of small pieces and will never peel off. The bottom on is in much better shape and I might be able to peel that off easier. I appreciate the input. I really need to take care of this. Hopefully when I get it done the surface is still good enough to just leave un-decaled. If it is bad I will have it painted.
Old 01-12-2018, 12:34 PM   #7
llr
heat it and use a plastic scraper
TT 2017 Flagstaff 831CLBSS Classic Ultra lite
TV 2014 Silverado 2500 HD
llr is offline   Reply With Quote
Old 01-12-2018, 12:36 PM   #8
dodr33's Avatar
Try a heat gun and oil based Goo-Gone...I had a Whizzy wheel damage my auto paint so be careful if you use it!
2017 F150 EB SCRW
2018 Shamrock 233S
dodr33 is offline   Reply With Quote
Old 01-12-2018, 12:43 PM   #9
NMWildcat's Avatar
Whizzy wheel works fantastic. I have used it on decals as cracked and dried as yours on my gelcoat. Remove any remaining glue with acetone. Just be sure to have a drill with the rpms that are suggested to make the job faster. Good luck!
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 01-12-2018, 01:01 PM   #10
My decals are noticeably above the gel coat, maybe try an Auto body decal eraser and mineral spirits (for the glue if any). Test a small area first, wash and wait for it to dry.
My first time getting the stickers and a small decal off involved a Costco membership card and mineral spirits. My gel coating wasn’t damaged at all.
Also I’ve seen my trailers brand decals on eBay. They are generic and not by Forest River.
Hope this helps.
wheels is offline   Reply With Quote
