One more thing to add, do not overlook the connection between the negative terminal of the battery and the frame. Ditto at the converter.
These connections are exposed to the weather and are often overlooked. Something could have snagged one of the wires and loosened it from it's connection to the chassis/frame.
Most people only focus on the actual battery terminals but do not overlook the other two, mostly hidden, connections that need to be in good condition to complete the circuit.
