I need to replace my two 6 Volt batteries in my 5'r. Do I need to worry about the order of disconnecting and reconnecting the batteries? Negative Versus Positive?
since the negative is usually the ground, disconnect it first so if you happen to have the wrench hit a grounded surface when disconnecting the positive, you won't get an arc.
Yep that is true
2011 GMC Duramax/Allison
2013 Puma 356QLB
Days Camped 33
Miles 6450
