Old 10-19-2014, 11:46 PM   #1
Enjoying the Good Life's Avatar
Bedroom Slide on Columbus 320RS
We have a 2014 Columbus 320RS fifth wheel and am unable to find a way to manually close the bedroom slide out. Don't have any issues with the slide yet but just wanting to be proactive for the day that a problem does happen. Anyone have an idea as to how this can be accomplished. This wasn't discussed during our walk through.
2002 F250 Ford Super Duty 7.3 PS (67K miles)
2014 Palomino Columbus 320RS Grey/Charcoal
Nights camped in 2015 98 and counting
Nights camped in 2014 186
Nights camped in 2013 130
Enjoying the Good Life is offline   Reply With Quote
Old 10-22-2014, 04:53 PM   #2
MacDR's Avatar
I have a 340rk, You bring up a great point.. Is there a way to manually bring in the bedroom slide? My dealer never mentioned it ..
Time to investigate..
2013 Ram 2500 "Cummins"
2014 Columbus 340RK
Day's Camped 2018 "32"
You can find us: CrockeryCreek RV Park, MI 9/29 - 10/1
MacDR is offline   Reply With Quote
Old 10-22-2014, 08:42 PM   #3
semi-senior member
denandra2's Avatar
Under the foot of the bed take the floor out to reveal the motor and shafts going to each side, You have to disconnect the shafts from the gear box and then you can manually push the slide in from the outside! How do I know? my 2014 320RS in June 2013 was three weeks old and shear pin from motor to gear box SHEARED! This is how I was told to do it by my dealer! Hope this helps and hope you never have to try it out!!!
Happy Camping
from sunny Fl already!
Dennis & RuthAnn
Tippy too!
Columbus (2014)320RS
2014 Ram 3500 DRW 6.7HO
Aisin 6speed Auto
SE Mo
denandra2 is offline   Reply With Quote
Old 10-23-2014, 07:26 AM   #4
MacDR's Avatar
Thank You for answering, I hope to never have to do this.. But will make sure I have the tools on hand and a couple of extra shear pins.
2014 Columbus 340RK
Old 10-23-2014, 11:13 AM   #5
Thanks for the information denandra2. I would also hope to never have to manually push in the slide. But at least now I know.
Old 01-01-2015, 11:50 PM   #6
Swift2
Swift 2's Avatar
Bed room slide out
Does the slide out have two separate motors, one on each side. I would like to create a longer storage area between the two motors to store my outside awning. I had done this on my previous trailer.
Swift 2 is offline   Reply With Quote
Old 01-02-2015, 02:28 PM   #7
amxpress's Avatar
Does your bedroom slide have the Shwintek setup?
2013 Palomino Columbus 320RS
2007 Dodge RAM 2500 6.7 Cummins
Reese 15K manual slider
Prodigy
M.I.L. in Florida for good!!
amxpress is offline   Reply With Quote
Old 01-05-2015, 11:03 PM   #8
Swift2
Swift 2's Avatar
Took the floor up in the bottom of the bed and found that the motor, shafts are bolted with 1/4 " bolts. Looks like forest river have cured the sheer pin problem. Looks really solid on our 320RS. I cut a door in the floor to get at it just in case.
320rs, bed, bedroom slide, columbus, roo, slide
