Old 10-31-2013, 05:47 PM   #1
Cyoul8r's Avatar
Bedroom Slideout Fuse/Circuit Breaker Location
I have a 2012 Palomino 32RCTS and cannot locate the fuse/circuit breaker for the bedroom slideout. At the top of the fuse panel there are two 30 amp 12v circuit breakers which control the couch and dinette slideouts (positions 1 & 2). Further down there is a 15A fuse (position 9) which is labeled slideout. I pulled that 15A fuse and the bedroom slide still works. Futher down is another 15A fuse (position 12) which is labeled S/O, which I assumed meant slideout, but when I pulled that fuse the slide still works. Can anyone having this model help me out on this? The slide works just fine but I want to be sure what to do if it doesn't.
2012 Palomino Sabre 32RCTS-6
2012 Ford F-250 Super Duty Fx4 6.7 Powerstroke
16K PullRite SuperGlide
Air Lift LoadLifter 5000 Air Bags
Cyoul8r is offline   Reply With Quote
Old 10-31-2013, 05:57 PM   #2
Ford Idaho's Avatar
Did you try it with both 15A pulled out?
Old 10-31-2013, 06:39 PM   #3
Cyoul8r's Avatar
Yes. It didn't make any difference...it still worked.
Old 10-31-2013, 07:21 PM   #4
VinceU's Avatar
Many slides are powered by in line fuses/circuit breakers located close to the battery. Look for them attached to the frame or inside basement walls with pretty good size DC cables.
bed, bedroom slide, breaker, cat, fuse, location, roo, slide, slide out
