Closed Thread
Old 04-24-2015, 08:18 AM   #61
Fulltime family RVer
Originally Posted by OldCoot View Post
Even Lippert has come out with a kit to reinforce the Equa-Flex which reinforces that it is an additional load on the frame.
Do you happen to have a link for that? I have the same camper as the Op and the same Equa-Flex suspension.
ependydad is offline
Old 04-24-2015, 08:50 AM   #62
DDC
DDC's Avatar
Originally Posted by DDC View Post
If you manufacture something that later turns out not to be built to do what it is supposed to do you are a possible target for being liable, “WARRANTY DOES NOT COME INTO IT” that is why I suggested to the OP that he should be reporting this to the NHTSA. FR would point out that it did not make the chassis, so and on till the truth comes out.
Originally Posted by TURBS View Post
What I'm saying is forest river "sabre" does not condone adding a hitch or pulling anything behind there 5th wheels.
If you do the warranty on the frame is void.
It's obvious that the op pulls a trailer behind his 5th wheel therefor warranty void.
Just stating facts.
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "2 nights"
Like I said this is not a warranty issue it is a safety issue, can you say categorically that "if this unit pulled anything behind it that that was the cause of the frames failure".
I must have missed the OP stating that he pulled anything, but, he has been missing from this conversation.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline
Old 04-24-2015, 08:52 AM   #63
TURBS's Avatar
Sorry I miss understood what you were saying.
As oc would say they kicked me out of kindergarten on the first day.
TURBS
TURBS is offline
Old 04-24-2015, 09:18 AM   #64
If you manufacture something that later turns out not to be built to do what it is supposed to do you are a possible target for being liable, warranty does not come into it that is why I suggested to the OP that he should be reporting this to the NHTSA. FR would point out that it did not make the chassis, so and on till the truth comes out.
The problem in this particular incident was self inflicted by OP attaching to the rear of the frame, which knowingly overloads the entire rig. Don't see any liability by anyone other than the OP. JMHO
OldCoot is offline
Old 04-24-2015, 09:20 AM   #65
Someone posted on the forum that they had it and posted pictures. Suggest contacting Lippert.
OldCoot is offline
Old 04-24-2015, 09:26 AM   #66
DDC
DDC's Avatar
I don't disagree but I would not bet the house on him loosing, like I said they would have to prove that his negligence was the direct cause of this failure and you have pointed out yourself that this is a weak point because of the stress put on the frame.
Think I'll change my name to "devils advocate".
DDC is offline
Old 04-24-2015, 09:28 AM   #67
Quote:...If you manufacture something that later turns out not to be built to do what it is supposed to do you are a possible target for being liable, “WARRANTY DOES NOT COME INTO IT” that is why I suggested to the OP that he should be reporting this to the NHTSA. FR would point out that it did not make the chassis, so and on till the truth comes out...
So, if I understand you, correctly, if I alter a frame even tho' I am warned/cautioned not to, and it later fails I should be able to report it to NHTSA? So, I can now alter the engine in my truck and if it blows up, I can go to NHTSA and report GM! COOL!
Hey Turbs, if your raising the front of your truck and re-tuning the engine blows up in your face, just report GM to NHTSA and let them go after GM. Neat!
OldCoot is offline
Old 04-24-2015, 09:41 AM   #68
DDC
DDC's Avatar
Now you are getting off subject, "National Highway Traffic Safety Administration" the key word being SAFETY but addressing the issue what you do to it has to be proven to have caused the failure. Has the OP said he towed anything with this unit? I see a picture on an earlier post but it was not posted by the OP, or did I miss one of him stating he did this.
DDC is offline
Old 04-24-2015, 09:43 AM   #69
TURBS's Avatar
Look at post #1229
Let see some off those tow rigs out there!!!!
TURBS
TURBS is offline
Old 04-24-2015, 09:58 AM   #70
He was even bragging about it working so great!
Bottom line, alter something and if it goes wrong, blame someone else is what I get from this thread.
OldCoot is offline
Closed Thread
bent, frame
