Old 06-06-2014, 08:05 PM   #1
Pirates55's Avatar
Bike Rack
So on my new sabre 36QBOK-7 I have the fold down bike rack. When in the up position the pins slide right in the holes......no problems. However, when I lower it to but bikes in it the pins don't want to slide through the holes. I can make them go through if I use a hammer and hit on the pins.
I've loosened the bolts that hold the rack on but it didn't help. I am considering taking a drill bit and reaming the holes out just a touch.
I wanted to see what solutions you guys may have that I've not tried or thought of before I started drilling anything.
Pirates55 is offline   Reply With Quote
Old 06-06-2014, 08:42 PM   #2
Same Problem
I had the same thing and my dealer did as you are suggesting. The only other thing I could think to do was to grind down the pads that support the rack (near the hinges) so it would come down a bit more. I think fixing the holes is the right idea as long as the pins are snug and do not allow too much play so the rack doesn't bounce. You would think this was rocket science to manufacture. I mean they make thousands of them. You would think they would work.....
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
Davidceder is offline   Reply With Quote
Old 06-06-2014, 08:45 PM   #3
Lloydg's Avatar
Send a message via AIM to Lloydg Send a message via MSN to Lloydg Send a message via Yahoo to Lloydg
If this is a new Sabre, I'd let the dealer fix it under warranty before drilling and reaming something that might void that warranty. I have the same fold down bike rack on my Surveyor and there is no problem to raise and lower. Good Luck.
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Ada, Michigan
Lloydg is offline   Reply With Quote
Old 06-06-2014, 08:46 PM   #4
jtstromsburg's Avatar
yup, I drilled out the holes as well. Touched up with with some black spray paint after drilling to help prevent rust. Works well now.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 06-07-2014, 05:50 AM   #5
Pirates55's Avatar
What size drill bit did you use JT?
Old 06-07-2014, 04:27 PM   #6
Think it was 5/8" if I recall. I may have also reamed it a little by wobbling the bit around, but I don't recall for sure.
It's still a snug fit after drilling, which is good while in use.
Joel and Teresa
2016 Sabre 34TBOK
Old 06-07-2014, 04:52 PM   #7
slide5r4fun's Avatar
We had the same issue on our 2012 Sabre 32RCTS. Only the holes in the bike/cargo rack frame were just under 3/4" and the holes in the trailer frame were 5/8". The result was about 3 - 4" of travel so the rack bounced like crazy when traveling down the road. I drilled all holes out to 3/4" and bought new hitch pins from Tractor Supply. Fixed the problem but I had to hammer the hitch pins in. I plan on using a dremel to ream out the holes just a bit so I can remove/install the pins without having to hammer them in.
Kevin & Janine
2006 Dodge 2500 Megacab CTD 2WD
2012 Palomino Sabre 32RCTS
Pullrite Superglide 16K Hitch
slide5r4fun is offline   Reply With Quote
Old 06-08-2014, 09:00 AM   #8
LaydBack's Avatar
I had the same issue. Just trued the holes up with a 5/8" bit, and pins fit snuggly, but go in with ease.
Sent from my SPH-L710 using Forest River Forums mobile app
LINK TO MY MODS
2012 F350 King Ranch DRW 6.7L
2013 Sabre 36QBOK-7 Platinum Package
LaydBack is offline   Reply With Quote
Old 06-08-2014, 09:39 AM   #9
Oklahoma Proud
MillerTime's Avatar
Im having same issue. I will ream the holes out this week.
Millertime- Sabre Handler
Old 06-12-2014, 09:54 PM   #10
Oklahoma Proud
MillerTime's Avatar
Got my rack reamed out today. I used a 3/4" step drill bit and wobbled it around on both sided of the brackets, till the pin slid in and out freely. Spent about 5+ minutes doing it.
I think my pins are about 13/16" or 7/8", maybe not, but a 3/4" bit just falls through the holes without touching a thing.
bike, bike rack
