Old 10-07-2016, 05:46 AM   #1
monde48's Avatar
Black tank flush
I'm wondering if someone could explain to me how to winterize the black tank flush
I have a 2013 Palomino fifth wheel 36 five
thanks for any help
monde48 is offline   Reply With Quote
Old 10-07-2016, 06:37 AM   #2
TURBS's Avatar
No need to winterize the btf
Old 10-07-2016, 07:34 AM   #3
SeaDog's Avatar
X2 what Turbs said, but if you are concerned you could run a little very low pressure air thru it with the dump valve open
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 10-07-2016, 07:39 AM   #4
bubbles's Avatar
Why would the dump valve have to be open. The tank is vented. There is no residual water left in the cleanout system. Water drains from both sides of the backflow preventer when input is removed.
Old 10-07-2016, 07:53 AM   #5
SeaDog's Avatar
Low pressure air means different things to different folks and the valve open ensures no sudden expansion of the tank and is my CYA
Retired Navy
Old 10-07-2016, 07:54 AM   #6
I think the rationale to opening the valve is to drain any water that might come out of the tank flush line. Even if it were closed I don't think that much water would come out of the line that it would affect the strength of the antifreeze dumped into the tank.
keith_h is offline   Reply With Quote
Old 10-09-2016, 05:29 AM   #7
monde48's Avatar
Thank you All
Old 10-09-2016, 07:43 AM   #8
Canadian Member
Here is a pic of what mine looks like after the connection port. Sorry it tilts to the left. The bottom of the pic is the right side. Mine has an elbow where the backflow preventer would normally be but the previous owner removed it so I use an external one.
As you can see, it's installed so that no water is retained. Water drains away from the backflow preventer on both sides - back out the inlet port and down to the flusher head. It wouldn't hurt anything to use low pressure air (under 30 psi) to blow it out.
2019 Rockwood Signature 8290BS, Reese Revolution pinbox and B&W Patriot 18K hitch
Old 10-10-2016, 04:55 AM   #9
monde48's Avatar
Thank you
black, black tank, black tank flush, tank
