03-18-2012, 05:03 PM
Black tank flush. F320
Hooked up to the black water flush on the new f320-rs for the first time. I don't hear any water running or draining. I don't see any valve to turn on for the black water flush. Hose is tight and full of pressure. Any advice. My old TT didn't have a black water flush
03-19-2012, 04:59 AM
Sometimes I have to turn the water on and then back off then on again sometimes to get the flow through the black tank flush. There is not a valve to turn just a hose connection. There is a check valve that may be stuck. Try turning the water on then off and on again. Works for me.
2014 Cedar Creek 34 RLSA-7
2015 Chevy Silverado 3500HD LTZ SRW
04-01-2012, 06:16 PM
Did you ever get the black tank flush to work? We are having the same
problem. Tried turning water on and off as recommended, still not working.
04-01-2012, 06:42 PM
Trudy
Yes I switched the two water lines in the storage area. I have the pictures if you need I can text or email you. It's under warranty but I bought a 30 dollar wrench to fix instead of coir hundred bucked in diesel to dealer
04-01-2012, 07:15 PM
Yes could you email pics. We have tried everything aside from ripping the floor out. ( not really, just getting frustrated) Can't figure out what's wrong.
Would greatly appreciate it if you could.
04-01-2012, 09:12 PM
Like ret2006 said the check valve may be stuck. Or it may have been installed backwards.
04-01-2012, 09:17 PM
We didn't have any problems. Dumped the first time at the dealer. DH says it is quieter than TT was. there is not a agitator in the 320RS it just sprays. He says it is very quiet.
Felicia & Jeff - Missouri
2013 Columbus - 320 RS 2012 F350 CC DRW - 6.7L PSD
2012 Camping 59 DAYS; 2013 50 DAYS; 2014 WAITING
04-02-2012, 06:43 AM
Mine works like a champ after switching the two water lines that go up and behind shower to check valve
04-02-2012, 09:31 PM
Trudy
I am having the same problem with the black flush valves. Could you send me pictures at cuttinchief@gmail.com.thanks
04-03-2012, 08:00 AM
Trudy and cuttinchief. Just emailed pics and explain action. Let me know if you have any questions
04-03-2012, 09:24 PM
Thanks for the pictures it will be an easy fix.
04-03-2012, 09:27 PM
post the pics on here while your at it !
By the way when I hook up my bw flush I cannot hear mine either BUT water runs out the bw drain so I know its working !
04-03-2012, 09:29 PM
Got the pictures thanks
04-04-2012, 07:05 AM
Before the fix you could not hear any water flowing out of drain. You can now .
04-04-2012, 07:11 AM
Just uploaded the water line pic under my profile pics. Can't believe what a common problem!
07-21-2014, 04:57 PM
i just bought a 2012 palomino columbus what lines did you switch my blackwater flush isnt working,,,, pressure to hose thats it
