Old 03-18-2012, 05:03 PM   #1
rugmanrn's Avatar
Black tank flush. F320
Hooked up to the black water flush on the new f320-rs for the first time. I don't hear any water running or draining. I don't see any valve to turn on for the black water flush. Hose is tight and full of pressure. Any advice. My old TT didn't have a black water flush
rugmanrn is offline   Reply With Quote
Old 03-19-2012, 04:59 AM   #2
ret2006's Avatar
Sometimes I have to turn the water on and then back off then on again sometimes to get the flow through the black tank flush. There is not a valve to turn just a hose connection. There is a check valve that may be stuck. Try turning the water on then off and on again. Works for me.
2014 Cedar Creek 34 RLSA-7
2015 Chevy Silverado 3500HD LTZ SRW
ret2006 is offline   Reply With Quote
Old 04-01-2012, 06:16 PM   #3
Did you ever get the black tank flush to work? We are having the same
problem. Tried turning water on and off as recommended, still not working.
trudy66 is offline   Reply With Quote
Old 04-01-2012, 06:42 PM   #4
rugmanrn's Avatar
Trudy
Yes I switched the two water lines in the storage area. I have the pictures if you need I can text or email you. It's under warranty but I bought a 30 dollar wrench to fix instead of coir hundred bucked in diesel to dealer
Old 04-01-2012, 07:15 PM   #5
Yes could you email pics. We have tried everything aside from ripping the floor out. ( not really, just getting frustrated) Can't figure out what's wrong.
Would greatly appreciate it if you could.
Old 04-01-2012, 09:12 PM   #6
Like ret2006 said the check valve may be stuck. Or it may have been installed backwards.
Old 04-01-2012, 09:17 PM   #7
Earth Station's Avatar
We didn't have any problems. Dumped the first time at the dealer. DH says it is quieter than TT was. there is not a agitator in the 320RS it just sprays. He says it is very quiet.
Felicia & Jeff - Missouri
2013 Columbus - 320 RS 2012 F350 CC DRW - 6.7L PSD
2012 Camping 59 DAYS; 2013 50 DAYS; 2014 WAITING
Earth Station is offline   Reply With Quote
Old 04-02-2012, 06:43 AM   #8
rugmanrn's Avatar
Mine works like a champ after switching the two water lines that go up and behind shower to check valve
Old 04-02-2012, 09:31 PM   #9
Trudy
I am having the same problem with the black flush valves. Could you send me pictures at cuttinchief@gmail.com.thanks
Cuttinchief is offline   Reply With Quote
Old 04-03-2012, 08:00 AM   #10
rugmanrn's Avatar
Trudy and cuttinchief. Just emailed pics and explain action. Let me know if you have any questions
black tank, black tank flush
