Old 07-10-2013, 05:15 PM   #1
Phat Phrog Physician
SabreDoc's Avatar
Question Black Tank Flush Question
Just wondering if this sounds like a problem or is normal:
After flushing the black tank on my Sabre 35QSIK until the outflow is clear, upon removing the hose from the black tank flush nozzle I notice some back-flow of water from the connection. Not a lot, maybe 1-2 cups worth. It appears clear and has no odor to it. When flushing there appears to be a nominal flow of water from the sewer connection (visually verified through a clear tank extender fitting) and the tank reads empty when I finish. Is this just normal back-flow pressure created by the tank nozzle or is this abnormal and indicates a flow problem?
Thanks,
Doc
Ron, Amber & Jordan
2011 RAM 3500 DRW/CC/LB Longhorn 3.73
2014 Sabre 35QSIK-6 Platinum Edition
SabreDoc is offline   Reply With Quote
Old 07-10-2013, 05:19 PM   #2
JDWeir's Avatar
If I understand what you are saying, mine does this also. Don't think it is a problem as I seem to recall someone here saying that there is a backflow preventer in the line and this is water draining back on the hose side of the backflow preventer.
Jim
TV, 2000 Dodge RAM 2500 Quad cab short bed, Cummins 5.9, Edge Comp, Gauges.
5ver, 2011 Palamino Sabre 31 RETS.
JDWeir is offline   Reply With Quote
Old 07-10-2013, 05:25 PM   #3
SabreDoc's Avatar
Hey Jim,
So there is a back-flow preventer already installed in the line between the flush nozzle and the black tank? That's good to know as I was thinking I would need an external one attached to my hose to prevent contamination.
Thanks,
Doc
Ron, Amber & Jordan
Old 07-10-2013, 05:30 PM   #4
JDWeir's Avatar
I think there is a back flow preventer, hopefully someone here can verify that.
Old 07-10-2013, 05:43 PM   #5
JDWeir's Avatar
Just crawled into the basement to look. The hose from the black tank rinse connection runs up out of sight then straight back down towards the black tank. I am thinking that it goes up to a back flow preventer.
HTH
Old 07-10-2013, 10:59 PM   #6
On my Columbus 320RS the black tank flush line runs up through the basement storage roof then goes up to a back flow preventer in the line that is behind the shower valve. Then it goes back down the way it came to the black tank where it is drilled in to the tank just above the black tank drain fitting.
So yes, the flush line will contain a bit of fresh water that will come out when you remove the hose. Unless that is, you put a shut off valve on the line to control the excess water while dumping.
SargeW is offline   Reply With Quote
Old 07-11-2013, 08:56 AM   #7
SabreDoc's Avatar
Thanks Sarge and JD!
Appreciate the help.
Doc
Ron, Amber & Jordan
Old 07-11-2013, 09:37 AM   #8
mjones12's Avatar
Originally Posted by SabreDoc View Post
Hey Jim,
Thanks,
Doc
I don't know, but I have just assumed there would be one. But just in case, I got a small brass backflow preventer from Lowe's for a few bucks, and I use it externally.
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
mjones12 is offline   Reply With Quote
Old 07-11-2013, 09:53 AM   #9
Herk7769's Avatar
I have a short black hose with two back flow preventer (one one each end) and a shutoff valve that I use for turbo flushing the tanks.
It is overkill since there is one at the tank, but why take any chances?
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 07-11-2013, 10:17 AM   #10
daydreaming about camping
jeeplj8's Avatar
When I recently replaced my water pump I was looking at the black tank flush line as it enters the camper. There is a back flow preventer mounted about 36 inches from the inlet on the side of the camper. This makes it easily accessible inside the cabinet where the water pumo is (which the thoughtfully mounted on top of the main power cord...)
It is also secured above the inlet. In other words, it looks to be designed to allow water in the line between the inlet and preventer to flow out the inlet.
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline   Reply With Quote
Old 07-11-2013, 10:33 AM   #11
jevanb's Avatar
Mine is installed in the wall next to the master John.. sure makes LOT of noise
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 07-11-2013, 10:35 AM   #12
Denver, CO
garbonz's Avatar
My backflow preventer which is under the bedroom sink is REALLY noisy when I am flushing the tank. Anyone else experience this?. Sounds like the valve is fluttering somehow.
2017 Fuse 23T
Old 07-11-2013, 10:57 AM   #13
bubbles's Avatar
Yes, typically, the backflow preventers are noisy and not an issue.
