Old 09-10-2015, 08:47 PM   #11
Left Coast
Like armor-all on steer'n wheel?
Old 09-10-2015, 08:59 PM   #12
Who Dares, Wins
doc73's Avatar
Yes! Or brake pedal... Or rear bench seat in your medic unit...
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is online now   Reply With Quote
Old 09-10-2015, 09:38 PM   #13
mike.t's Avatar
Have used cooking oil in commode....fixed leaking in to tank with valve closed....wouldn't hold water and valve was very clean
Would you like to expand on this?
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 09-10-2015, 09:45 PM   #14
Left Coast
Why certainly......the cooking oil softens up the rubber slightly and like a lite grease, fills any voids temporally... need to let it sit for a day or two in bowl. Been hold'n water for 2 months now.
Old 09-10-2015, 09:47 PM   #15
trbomax's Avatar
Tell us about "pam" sounds interesting.
Pam cooking spray,Youve never heard of that? you need to go to the grocery store more often!
trbomax is offline   Reply With Quote
Old 09-10-2015, 09:58 PM   #16
mike.t's Avatar
I know what "pam" is. You used it how did it work compared to the "fluid"
2015 Salem 27RKSS
55' Chevy Bel-Air
Old 09-10-2015, 10:01 PM   #17
Fulltime family RVer
Can someone explain how you apply the spray? All I have is a handle at the end and it disappears behind my enclosed bottom...?
I have a blank tank oull they is really getting to be hard to push back (and pulling is a little difficult.
ependydad is online now   Reply With Quote
Old 09-10-2015, 10:09 PM   #18
CCRVOC
Ramblin Recks's Avatar
I had same problem. I had to pull the handle so hard I thought it would break. I tried spraying some lube into the cable but to no avail. When at Goshen, the fine folks at Cedar Creek replaced the cable (not the valve) and now it is a "two finger" pull/push.
2012 Dodge 3500, SLT Big Horn,CC,DRW,Cummins HO, EB, 4x4, 3:73, Retrax Pro, Q20, TST507, Garmin RV760, Sleek 4g
2014 Cedar Creek, 36CKTS, 640w Solar, TriStar MPPT 60, Magnum 2000w, PI EMS, WiFi Ranger Elite, Sleek 4g, Wingard DTV Traveler
Retired Army in 1995, and now retired in 2016
Ramblin Recks is online now   Reply With Quote
Old 09-10-2015, 10:11 PM   #19
trbomax's Avatar
Fluid Film is light years ahead of pam.I use it on hinges,locks,chain drives and sprockets,anything that moves . Its the only spray lube in my tool box (in the toy hauler).I guess the biggest thing is the little wand you can insert into the nozzel so it doesnt spray where you dont want it.
Old 09-10-2015, 10:18 PM   #20
mike.t's Avatar
Make sure all of your tanks are empty. Open the valve (pull the handle) spray what ever you are using on the shaft and close and open several times. Repeat other tank valves.
2015 Salem 27RKSS
55' Chevy Bel-Air
black, black tank, tank
