Old 07-20-2017, 04:39 PM   #1
BuckeyeChuck's Avatar
Black tank odor coming from kitchen cabinet
I have a 2013 Sabre 33ckts. There is a black tank odor coming from the slide-out pantry. The pantry is located forward of the island. This pantry back wall is shared with the bathroom where the toilet is located. Any ideas of what might be causing this?
2012 F250 Super Duty
2013 Sabre 33CKTS
BuckeyeChuck is offline   Reply With Quote
Old 07-20-2017, 04:52 PM   #2
Do you have a vent under your sink?
2019.5 Rockwood 2509S
Toddupton is offline   Reply With Quote
Old 07-31-2017, 02:24 PM   #3
Not that I can see.
2013 Sabre 33CKTS
Old 07-31-2017, 08:29 PM   #4
Your Air Admittance valve has failed. Probably somewhere in your island or sink area. Lowes has them for about $ 6. pick up a couple easy to change no tools needed, only hand tight. Find it and replace, your odor should go away.
Mike Tav is offline   Reply With Quote
Old 08-08-2017, 12:21 PM   #5
Thanks for the reply. I'll check that out.
2013 Sabre 33CKTS
Old 08-21-2017, 04:57 PM   #6
There is a valve unter the sink in the island. But I would think that that pipe would go to the grey tank not the black tank.
2013 Sabre 33CKTS
Old 08-21-2017, 09:40 PM   #7
After a few years the grey tank smells really bad.
2011 Flagstaff 831FKBSS
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 08-23-2017, 12:06 PM   #8
Yes it can!
2013 Sabre 33CKTS
Old 08-29-2017, 05:10 PM   #9
If you can locate that vent, replace it and see if it helps.
Old 09-06-2017, 04:09 PM   #10
Thanks. I found one under the kitchen sink but I thinks that is for the grey tank. The order was comming from elsewhere.
2013 Sabre 33CKTS
black, black tank, tank
