Old 10-09-2016, 09:30 AM   #11
scbrown063's Avatar
Originally Posted by Iggy View Post
Here is a short video.
https://youtu.be/u-AFa9hyrpI
Thanks Iggy. Looks like I have a little project for next weekend.
scbrown063 is offline   Reply With Quote
Old 10-09-2016, 12:28 PM   #12
Havasu Bill's Avatar
My Cardinal was only 6 months old when I had to replace the black water valve. FR puts in cheap valves/cables (twisted wire). I replaced it with an of the shelf good quality valve (can't recall the name) with solid wire. I also cut a 3 sided hatch in the underbelly to get access to it now and in the future.
It works so much better and smoother now! Amazing what quality gets you
Bill
2016 Forest River 3250 Cardinal
2016 RAM 2500 Longhorn
Previously: 36' Country Coach
Havasu Bill is offline   Reply With Quote
Old 10-09-2016, 01:33 PM   #13
We have a Chaparral 360IBL and the black tank handle was hard to from day 1 just like yours. After about a year of fighting with it, it finally won. It broke off in my hand one day. I pulled the underbelly skin off to get to it and discovered a major design flaw. The black tank is mounted about 10" in front of a cross brace. To route the cable to the blade valve, it had to make a 90* bend at the valve connection causing a huge amount of friction at the bend. My solution was to drill a 1/4" hole in the brace and run the cable from behind the brace straight into the valve connection. Smooth as silk now.
Goferbroke is offline   Reply With Quote
Old 10-09-2016, 03:37 PM   #14
Tom48's Avatar
Originally Posted by scbrown063 View Post
Thanks David.
Is it a direct pull handle or does it have that darn cable?
In our old rig, at about 7 years I changed the whole valve and NEW was so nice.
Tom48 is online now   Reply With Quote
Old 10-10-2016, 10:48 AM   #15
I went through two cable operated black valves with poor results. I gave up and replaced with an electric valve. It has worked well and solved the problem.
Harkerr is offline   Reply With Quote
black, black tank, tank
