Originally Posted by scbrown063
Ok I will try it. What does that do?
I swear by Dawn as the magic elixir for almost everything.
The truth is Dawn is a great degreaser and won't hurt rubber seals or birds.
Anyway it's worth a try.
You just may have toilet paper stuck in the valve that has dried and isn't coming out.
If you don't mind getting a little dirty....
You can remove the valve yourself after you do a few good water flushes and see if you can manually clean the valve seat. It's only 4 bolts and nuts.
