Old 04-28-2015, 02:54 PM   #11
Or just save yourself a lot of trouble and replace the whole system with a see level monitor that does not go in the tank. Since it is on the outside nothing gets "stuck".
https://www.garnetinstruments.com/rv-shop/products/
2016 Flagstaff 23lb
Toddupton is offline   Reply With Quote
Old 04-28-2015, 02:55 PM   #12
Witch Doctor's Avatar
Originally Posted by siskom View Post
Sure fire fix...When you are leaving for a outing to a park that has a dump station put 1/3 full water (estimate) put two or three bags of ice down toilet and drive the ice will act as a cleaner in the water and clean off any stuck debris when you arrive at location dump tank before parking.
There is a myth buster on u-tube, he put ice in and showed it has no affect at all. Along time ago I did the stupid thing of leaving my black tank valve open hooked to a sewer, never been hooked to before. Well we all know what will happen. And it did. Had a mobile repair guy and he said he didn't want to touch it being I would need to replace the tank being it was full. Well I went and got some of that disgust stuff And put like 3 times the amount in. It sat for two days. Then I pulled the handle and walla out it came. I mean it was plugged solid. I would get that stuff and fill my tank full with water and dump that in and let it sit for a couple of days or even a week it will clean it out.
Coachmen M/H
Concord
2018 / 300 DSC
Old 04-28-2015, 03:00 PM   #13
Herk7769's Avatar
I would recommend RID-X or RV-DIGEST-IT in 4 gallons warm water; fill to capacity and let sit 72 hours minimum.
The enzymes and bacteria will clean the scum off the walls.
The Calgon water softener and detergent are a great "after every dump" to prevent this from happening in the future.
HAM CALLSIGN - KC3FFW
Old 04-28-2015, 03:08 PM   #14
siskom's Avatar
mythbusters
Put some toilet paper in a five gallon pail let it dry to the sides put bag of ice in and water shake it around send results to myth busters.
siskom is offline   Reply With Quote
Old 04-28-2015, 03:10 PM   #15
Send a message via MSN to Tiggerdad
Leave the ice out and shake it around. Paper will dissolve.
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
Tiggerdad is offline   Reply With Quote
Old 04-28-2015, 03:19 PM   #16
BamaBob's Avatar
X2 on the RV DigestIt. It is expensive but magical stuff!
For your day to day chemical treatments, we picked up this nifty gadget at last year's FROG Rally in Goshen:
Chemical Dispensing Systems for RV & Marine | Blue Streak LLC
We use a homebrew chemical - 1/3 PineSol, 1/3 Dawn, & 1/3 Water (a mix developed by OldCoot) cheap as can be and works like a charm!
We add a dollop of calgon to each gallon we mix. Pack it away and fill the BlueStreak as needed throughout the year.
1 -2 times a year on especially long campouts (1+ week) we will dump in a cup of RV DigestIt and let it do it's magic
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 04-28-2015, 03:25 PM   #17
bubbles's Avatar
Kind of late for this input but if one would use this procedure from the start there would never be a problem. All my units never had an issue with black tank readouts following these steps. I could not do this at a dump site as there were other campers waiting. Takes about 20 minutes for my tank to fill up. Flying J's is where I dumped when not coming from an rv park with full hookups. Anyway the indicators always read correctly. Watch the video if you have time.
Old 04-28-2015, 03:42 PM   #18
Herk7769's Avatar
RV Tank Sensors &The GEO Method | Wheeling It
Ice cubes do not work at all.
Old 04-28-2015, 03:51 PM   #19
1 cup Super Clean, 1 cap Pinesol, rest water in the Blue Streak 1 quart Super Clean, cup Pinesol 5 gal. water and tow for the grey tanks.
Correction in Red.
Old 04-28-2015, 07:29 PM   #20
derek6669's Avatar
Your initial idea was almost the same as the geo method. I tried the geo method last fall and got the results I was hoping for. I have now made up 8 bottles to start the season and plan to treat the black & galley tank every 2nd dump. The grey will look after itself with. Here is the link. https://sites.google.com/site/cbruni/
derek6669 is offline   Reply With Quote
water, black, black water
