Old 03-19-2014, 10:44 AM   #1
doc701's Avatar
Brake issue
I have 2012 Sabre 31RETS I bought on 4/4/2012. I also bought a 2012 Ram 2500 to pull it at the same time. While on a trip last fall I got a fault code on my built brake controller that said to check the trailer brake wiring. I lose my trailer brakes when this code is displayed. The code only stays on for a short period, maybe 30 seconds or so. this may happen 10 to 20 times a day, or it may not happen for several days at time. I have had four mechanics look at it and they can't find anything wrong with it. One suggested it might be the brake controller. Has anyone had a similar problem. HELP!!! I am afraid to use this trailer.
doc701 is offline   Reply With Quote
Old 03-19-2014, 10:56 AM   #2
VinceU's Avatar
Think of two causes: as you said defective controller or brake lead touching ground? I'd bet on the controller.
Old 03-19-2014, 11:09 AM   #3
I'd have to go with the brake lead touching ground being a more common problem and knowing the way FR wires things.
Old 03-19-2014, 11:09 AM   #4
Could be the connector between trailer and truck maybe...bad crimp or something loosing contact when you hit a bump...
_______________________________________________
Tim & Jenn
2009 Forest River Grey Wolf 235 5er
2003 F-350 Superduty 6.0 l Diesel
DSP 17K
aiscpl6 is offline   Reply With Quote
Old 03-19-2014, 11:19 AM   #5
Witch Doctor's Avatar
or hitting metal and shorting out. Add a 3 amp fuse in line and see it if blows, if it blows it a short not the controller.
Coachmen M/H
Concord
2018 / 300 DSC
Old 03-19-2014, 11:22 AM   #6
Pirates55's Avatar
I had this issue on a travel trailor and it was a skinned wire touching metal and shorting out the system. Mine was in the axle where the wires went from on side of the trailer to the other.
Pirates55 is offline   Reply With Quote
Old 03-20-2014, 12:11 AM   #7
The most common cause that I see at work is a poor connection at the 7 way plug. Lightly sand the contacts of the vehicle side and gently spread the contacts to provide a tighter fit with the trailer end. The contacts in the vehicle side are a folded over design "v" and can be slightly spread apart. This procedure has repaired approx. 90% of the faults.
2012 Palomino Ultralite T245
2004 F250 Supercab 5.4L
09 Grizzly 700 EPS
09grizzly1 is offline   Reply With Quote
Old 03-29-2014, 08:30 AM   #8
BigTJohn's Avatar
What Grizzly said is most likely cause. Clean connections and add dielectric grease to protect them.
Brenda and John
Master Blaster of the Navy
BigTJohn is offline   Reply With Quote
Old 03-30-2014, 09:16 AM   #9
Had a similar issue a couple of years ago after some major rain. Water had got into the connector.
ex-egll is offline   Reply With Quote
brake
