Old 10-23-2014, 12:36 PM   #91
MacDR's Avatar
Found out today that my 2014 Columbus 340RK has grease on its brake pads .. We had gotten the service bulletin in the mail from Lippert and asked our dealer to check while winterizing.. New assembly's will be arriving in a couple of weeks..
2013 Ram 2500 "Cummins"
2014 Columbus 340RK
Day's Camped 2018 "14"
You can find us: Egg Harbor Campground 7/9 - 7/11
MacDR is online now   Reply With Quote
Old 11-15-2014, 12:55 AM   #92
Broke and happy
bobfa's Avatar
I am a new member of the club. My 2014 340rk had its brakes checked today and all 4 hubs and brakes were greased up. Compared to my old trailer, this trailer acted like it had weak brakes, from day one. Set the gain all the way up, from the beginning my first day, and put 6000 miles on the trailer.
bobfa is offline   Reply With Quote
Old 11-15-2014, 06:16 AM   #93
Witch Doctor's Avatar
Lippert has just came out with a new design and a more aggressive break pads and larger magnets. There is a special break in period if you do not follow they will glaze over and not work correctly. My thinking is that when the trailer is delv. I know that the person pulling them is not doing it being it takes some time. They put these on my unit and I followed there instructions to the tee. Now they are seated and will stop you on a dime almost. But sure beat the ones that I used for over 10,000 miles and were always weak. Lets hope they are making progress. At least we can hope..
Coachmen M/H
Concord
2018 / 300 DSC
Old 02-25-2015, 06:10 PM   #94
Travler's Avatar
Update. Took the trailer and letter to dealer. They found grease on brakes. Now getting parts. Should be ready by camping time.
Travler is offline   Reply With Quote
Old 02-25-2015, 08:06 PM   #95
Smoker's Avatar
Bearing change
We purchased our 295 Columbus in September, knowing all the brake issues, I simply replaced all 4 wheel bearing (using timkins) removing the Chinese junk and replacing the grease with a PN SKF 22532. A much better seal than stock. Each wheel cost me around 100 dollars but its worth it knowing I have good parts under me.
2014 RAM 2500 4X4 CC 6.7TD
2015 Columbus 295
18K PullRite SuperGlide
Firestone Ride-Rite Air Bags
40 Gal AUX TANK
Smoker is offline   Reply With Quote
Old 02-25-2015, 10:19 PM   #96
Broke and happy
bobfa's Avatar
Mine work great now but I insisted dealer to adjust them after I did a burning in drive home and back. They perform like they should with Co troller set on 6 and will bite down if you need them. Very important to burn the breaks then adjust.
columbus, brakes
