Old 11-06-2014, 01:09 PM   #1
Brake problem 2013 Columbus 320RS (Electrical?)
After living with recurring brake problems on my Columbus 320 I finally changed out the brakes and put new seals, brakes, magnets and packed wheel bearings. Still not satisfiyed with the brakes and after checking the voltage to the brakes, it reads 10.2 volts. I thought someone said it should be 12.2 volts. If so, what and where do I look next? Brakes just don't seem to be applying hard enough when stopping.
"totally frustrated"
Mr.z is offline   Reply With Quote
Old 11-06-2014, 01:57 PM   #2
From what I was told it should read 12volts... Is the controller set to full power?? Did you check all your grounds?
2010 Georgetown 300FWSSouth Florida
speedjester is offline   Reply With Quote
Old 11-06-2014, 02:07 PM   #3
TURBS's Avatar
You didn't mention adjusting the brakes?
BTW over the years I've found once you've adjusted them you have to go back and adjust them a few more times to get them "right"
I adjusted my sabre brakes not long ago after the trip, they seemed "ok" I then had to go back once again and gave them even more.
Now they'll rip your head off at full power!
BTW you have the same axles and brakes I have.
Turbs
Old 11-06-2014, 03:13 PM   #4
We did adjust the brakes and we're sure they are within "grabbing" distance of the drum. So in order to check out the controllerer, we by-passed the controller in my 2012 F250 and hooked up a new controller (can't remmber the name) and had the same problem. I'm guessing there's a ground problem because the 10.2 volts was coming from the shops trailer hook up. (a device that you plu the trailer into the shop tester without a truck) So, if it's a ground problem where do I start looking?
Old 11-06-2014, 03:15 PM   #5
TURBS's Avatar
Start at your connections behind your backing plate and move forward.
The use cheap ass scotch locks that are a wiring no no!
Turbs
Old 11-06-2014, 03:19 PM   #6
I don't understand "backing plate". Please explain. What are scotch locks? Are they the screw on wire connectors vs the crimp connectors?
Old 11-06-2014, 04:11 PM   #7
DDC
DDC's Avatar
Sounds like you are experiencing resistance, have you checked the voltage at the truck plug, if it is ok start from there back to the axles cleaning all connections or replace them.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 11-06-2014, 04:14 PM   #8
TURBS's Avatar
Backing plate and scotch locks.
Turbs
ID:	65948   Click image for larger version
Old 11-07-2014, 10:55 AM   #9
f1100 Turbo - thanks for the drawing. Don't know why I didn't understand backing plate - must have been a brain fart!
Old 11-07-2014, 10:59 AM   #10
TURBS's Avatar
Your fine!
Carry on!
Turbs
2013, 320rs, columbus, electric, electrical, brakes
