Old 05-16-2014, 08:47 PM   #41
Broke and happy
bobfa's Avatar
Originally Posted by AnchorsAweigh View Post
Yep Suggest you have someone open & close the slide while you watch your outside wall. Stress Cut is BS how else can you peel the skin to fix the stud.
Factory said there was no stud or structure loose. Defect was only a delaminaton where this stressed area the glues failed to bond. When the camper arrives, we will run the slide and inspect carefully, thanks.
bobfa is offline   Reply With Quote
slide, slide out
