Old 10-16-2018, 08:20 PM   #1
Duramax2017's Avatar
Bypass valve
I can not believe that Forest River did not install a bypass valve on the Palomino Columbus 383FB, for the hot water heater how are you suppose to winterize this unit with antifreeze? your hot water heater will fill up with antifreeze with out a bypass valve.
Duramax2017 is offline   Reply With Quote
Old 10-16-2018, 08:27 PM   #2
Mr. Dan's Avatar
My guess is that your unit really does have bypass valves. How about posting a pic of all the plumbing on the back of your water heater.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 7; booked = 22
Old 10-16-2018, 08:29 PM   #3
I looked there is no access panel to the back of the water heater
Old 10-16-2018, 08:47 PM   #4
What is behind your HW heater? Our access panel is actually to the side of the heater. However directly behind is the dresser in the bedroom and I can remove a drawer for access as well.
2019 Hemisphere 272RL
2007 Silverado 2500HD 6L
Cabinfever97 is offline   Reply With Quote
Old 10-16-2018, 08:56 PM   #5
when I looked I seen one access panel behind it was a fuse panel that was all I seen do you have a Columbus 383FB?
Old 10-16-2018, 09:10 PM   #6
cavie's Avatar
Trust us. Your WH does have a bypass valve, or 2, or 3. look for a removable panel.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
cavie is online now   Reply With Quote
Old 10-16-2018, 09:21 PM   #7
ok I will look again thanks
Old 10-16-2018, 09:27 PM   #8
bikendan's Avatar
You just havent found it because a Columbus would surely have one.
By the way, Palomino is the manufacturer. It's a division of Forest River Inc.
Equalizer WDH
Old 10-16-2018, 09:33 PM   #9
Well I called the dealer today and they told me just put it in winterize mode and you will be good to go for winterizing it, not true I called them back and said there is anti freeze running out of the hot water heater, they said I will call the factory and ask them where the bypass valve is, he called me back and said that the factory say there is not a bypass valve on those units, I still can not believe that at all there has to be one.
Old 10-16-2018, 09:56 PM   #10
Canadian Member
According to all the websites and YouTube videos I found online, your Columbus has the Nautilus water management system so you use that to winterize and bypass the water heater.
Go to 3:51 in this video.
https://youtu.be/JpNKQ0Vteo4
2019 Rockwood Signature 8290BS
valve
