Old 12-12-2016, 01:41 PM   #1
monde48's Avatar
cable will not work
I have a 2013 Palomino Columbus fifth wheel for some reason I cannot get my cable to work. This is the very first time trying I don't know if there is a trick to it. But if someone could help very much appreciated
monde48
monde48 is offline   Reply With Quote
Old 12-12-2016, 01:43 PM   #2
Ford Idaho's Avatar
Antenna booster off?
TV set to cable and channel scan done?
Old 12-12-2016, 01:55 PM   #3
monde48's Avatar
the booster is off I you also I ran a cable through my slide out and hookit up directly to the TV everything worked fine. could be something wrong with the wiring
Old 12-12-2016, 02:25 PM   #4
Ford Idaho's Avatar
Yes it is possible there is an issue with the wiring there are posts here about that.
Myself I found some loose connections on the splitters and where the cable hooks to my trailer.
Old 12-12-2016, 07:31 PM   #5
brookstone345sa's Avatar
If you have 2 places to hook up cable try and switch them. Mine were not marked however 1 is for cable, 1 is satellite hook up. I switched my cable and it worked. Don't know why. Maybe my second one is not hooked up.
brookstone345sa is offline   Reply With Quote
Old 12-13-2016, 01:19 PM   #6
Try using the satellite mine are switched so for cable I have to use the satellite. They installed them wrong
colo native is offline   Reply With Quote
Old 12-13-2016, 02:15 PM   #7
cable will not work
I found that on our Crusader Lite, built by Prime Time that the satellite and cable connection on the exterior of TT were mislabeled. I connected the satellite to the connection marked for cable and it worked great. Cable and satellite wiring has different kind of cable installed.
Walholler is offline   Reply With Quote
Old 12-13-2016, 03:29 PM   #8
mule's Avatar
X2 with brookstone, left connection is cable and the right is satellite on our rig. And just in case, check your input with your remote.
Good Luck!
mule is offline   Reply With Quote
Old 12-13-2016, 04:05 PM   #9
The connection markers on mine were switched. So we're my black and grey tank markers.
Okie
USMC Okie is offline   Reply With Quote
Old 12-13-2016, 05:08 PM   #10
Left Coast
Easy way to check.....
Old 12-14-2016, 08:12 AM   #11
nikita's Avatar
On our 2010 Sabre Palomino - our first maiden voyage down to Florida in it - we arrived at our first stop in VA KOA. We hooked up to the campground Cable and it would not work. The manager came over tried to help us and he said it was our camper, not his CG Cable. We stopped at a Forest River Dealership in Easley SC - The repairman there removed our TV and went into the wall behind it. He said the wires were there, but they were never properly hooked up. He fixed it - then no problem, always had cable.
Nikita
2020 Chevy Silverado Diesel 2500HD
2015 Sabre 33 RETS 5th Wheel
nikita is offline   Reply With Quote
Old 12-23-2016, 09:36 AM   #12
amxpress's Avatar
The wires weren't hooked up properly on our 2013 320RS when we picked it up new. I switched the wiring around and have never had anymore problems, unless I forget to turn the antenna amplifier off.
2013 Palomino Columbus 320RS
2007 Dodge RAM 2500 6.7 Cummins
Reese 15K manual slider
Prodigy
M.I.L. in Florida for good!!
amxpress is offline   Reply With Quote
cable
