Old 07-15-2019, 09:46 AM   #41
Originally Posted by litgrep View Post
Also, are you sure you're getting a charge from your tow vehicle. Many vehicles sold prepped for towing don't hook up the 12v charge to the trailer plug. Mine was even strapped to wiring harness to the fender box and no fuse in the box.
Thanks for that info. As a new travel trailer owner I would like to know what the is best method to test to determine if the towing vehicle is providing power to charge the batteries please? Thanks. BTW I am towing with a 2011 Ford F150 Lariat with the Class IV tt package.
flyboy43 is offline   Reply With Quote
Old 07-15-2019, 09:50 AM   #42
Open your tow plug receptacle lid and check for voltage with the engine on and with the key/engine off at pin/blade # 4.
Name:	tow plug-receptacle wiring.jpg
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 07-15-2019, 10:58 AM   #43
Probably only charging when the vehicle is turned on. Check the battery voltage on your trailer with the engine off followed by the engine running. If the voltage goes up, the truck is charging the batteries. Don't get to excited about that charge though. Will likely only be a couple of amps. There are things you can do to increase it if it's important that it charges your battery at a higher current though.
babock is offline   Reply With Quote
Old 07-15-2019, 02:52 PM   #44
Easy Peasy
Test the voltage of your battery bank. If charged it will be 12.6 or so.
Hook to the truck. Start the engine. Test your rv battery again.
13.1 or less is a trickle charge from the tv. More is better but, not likely.
Few trucks do better.
tomkatb is offline   Reply With Quote
battery
« Grey tank | DSI »
