Old 12-29-2018, 08:12 PM   #1
kholmes's Avatar
Can someone answer my battery question??
Hi all just left Canada on the 27th of Dec. Left minus 10 Celsius temperatures. Had unit plugged in for weeks to make sure batteries were fully charged. Drove for 10 hrs first day arrived in minus 6 degree temps in Montana and stayed in hotel. Rig not plugged in. Drove 12 hrs next day and nighted over in walmart parking lot. Furnaces started and worked great but in 2 to 3hrs batteries had dropped down from fully charged to 3rd charge and where dead by am. Froze are butts off. Is it normal for batteries to drop charge that quickly. I have 2 newer 12volt batteries. Ran furnace and no lights. Only draw that I think we had outside of furnace was co detector and fire alarm. Would it be normal to lose all battery capacity from 2 batteries in 7 to 8 hrs?? Thanks everyone one and Happy new year to all.
Randy
Kim & Randy Holmes
2016 F350 Turbo Diesel FX4
2014 Palomino Sabre 33 CKTS
(2012: 10); (2013: 17); (2014: 33); (2015: 43);
(2016: 37); (2017: 69); (2018: 90)
kholmes is offline   Reply With Quote
Old 12-29-2018, 08:15 PM   #2
How many hours are your furnaces on? On my small trailer, my one furnace draws around 7A. For me, if my furnace is on 50% of the time for 8 hours, that's 28AH. What other loads do you have besides your furnace? Residential fridge?
What does "3rd charge" mean?
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is offline   Reply With Quote
Old 12-29-2018, 08:22 PM   #3
kholmes's Avatar
had set at 70 degrees not sure what time it shut down. Nothing else running but it didnt make it through the night cause their was frost on my wife's pumpkin!!
Kim & Randy Holmes
Old 12-29-2018, 08:35 PM   #4
70 degrees and it was 14°F outside? I bet your furnaces were on 100% of the time. We set ours to 60 at the highest to preserve battery and that is with much warmer temps.
Old 12-29-2018, 08:48 PM   #5
Flybob's Avatar
If original batteries, they are at least 4 yrs old and running furnace at 70F all night can easily drain batteries below the shut off voltage for the furnace. Easy quick solution extra blankets and temp at 55F or 60F overnight.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 12-29-2018, 09:17 PM   #6
Based on what I gathered from your post (OP's) your batteries may not have been fully charged once you unplugged the first time.
Merely driving for a normal days travel won't provide enough current to fully charge a battery that's powered a furnace for any length of time, along with the usual power consumption. If you don't stay in a campground and plug in, a generator is pretty much a necessity to recharge the batteries anywhere near full.
I like to start my generator in the morning when I first start moving (as long as I'm not in a restricted "generator hours" place and let the converter/charger put as much power in the batteries as possible. This higher current also warms the batteries so they will more readily accept a charge which is as much a chemical reaction as electrical. Heat speeds chemical reactions and the published "Ideal Temperature" for batteries is 77 degrees (electrolyte temp).
While the Generator is running I can brew coffee, use the microwave, toast bread, and all the other things one often does for breakfast. Once ready to hit the road again, turn off generator and NOW let the Tow Vehicle finish off the charge as you drive to your next stop.
As for where to set the thermostat, I started camping in tents so snuggling into a nice warm sleeping bag was how we did it. Now that I am in a trailer I set the furnace down to it's lowest setting (55 degrees on mine) and rely on the sleeping bag for warmth (along with my dog that burrows in with me). This setting will keep things from freezing and it doesn't take long to warm up in the AM. Before my wife passed away and she was still camping with me she'd wake me and tell me to start the furnace. Funny how marriage works
In closing, I don't know what your battery setup is but just adding more, larger batteries won't really help unless you have a way to make sure they are fully charged before the next eve's stop. Tow vehicle charging current (to trailer) drops rapidly after the engine is started with trailer connected. It's caused by the small wires between TV battery and Trailer Batteries. Large voltage drop makes the charging system think everything is fully charged and voltage is regulated downward.
That was pretty long so I'll call it my "three cents worth".
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 12-29-2018, 10:04 PM   #7
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
The furnace fan is a power hog like no other.
If you have 2 smallish hybrid batteries especially in sub freezing weather and when the batteries are exposed to the cold 1 - 2 nights sounds about right.
2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 12-30-2018, 02:22 PM   #8
I would also assume that you retracted, extended your slideouts, that alone would have pulled a lot of juice from your batteries.
tomrob1161 is offline   Reply With Quote
Old 12-30-2018, 02:32 PM   #9
TGR
TGR's Avatar
I have a single battery in my 5th wheel trailer that can’t make it through the night running the furnace. I would have thought that two batteries would have kept you warm all night but I’m not too surprised that they failed with the temperature going down -10 C.
I don’t have any issues with my truck charging my battery while traveling. It keeps fully charged and even gets its charge topped off between overnight stays when traveling for several hours between stops. Out of curiosity, I would check to ensure your tow vehicle is sending current to your battery while traveling just to be sure everything is working properly.
When camping in cold weather for several days, I use a generator to both keep the power going for the lights and furnace and to run a dehumidifier as I feel there is too much condensation in the trailer for its own good under these conditions.
2015 Wildcat 282 RKX
2011 F350 Lariat, 6.7 L. Diesel, 8 ft., SRW, Reese R20
TGR is offline   Reply With Quote
Old 12-30-2018, 02:39 PM   #10
Interestingly enough these aren't the big drain that kills batteries. I measured the current to extend/retract my slide and it was only around 10 amp as I recall. Current draw only lasted for a minute or less.
At that rate, for that amount of time, the power consumption was less than 1/4 amp hour.
My furnace fan only draws 5 amp max and the reason it consumes so much power (amp hours) is the fact that it can run for 4-5 hours in an evening in total, longer if really cold. If you have a sigle 100 ah battery it's easy to drain one overnight if one insists on using the "extra cozy" setting on the thermostat Now add in the lights, TV, Stereo, Water Pump, Fan, charging cell phones, etc and it's easy to see where battery "energy" goes so quickly.
2004 Nissan Titan
battery
