Old 02-22-2017, 08:41 PM   #1
Can't find hot water bypass valves
We have purchased a 2015 Columbus Palomino 320 and took a short trip this past weekend. The hot water heater is getting hot but no hot water is getting to any of the faucets. I have tested the water at the relief valve and water is hot. I have searched everywhere for a bypass and can't find it. Any ideas. Thanks
D Sloan is offline   Reply With Quote
Old 02-22-2017, 08:58 PM   #2
wmtire's Avatar
Maybe this thread (4th paragraph) can help you locate the winterization valves.
http://www.forestriverforums.com/for...st-103381.html
2011 Flagstaff 831 RLBSS
Just imagine, for a moment, if there were no hypothetical situations.
Old 02-22-2017, 09:04 PM   #3
Otegoans's Avatar
I don't have your model RV but as far as I know the bypass valves are right on the back of the water heater. Sounds to me the valve on the discharge is closed. You'll probably need a flashlight to see into the access to the heater.
Otegoans
Ken and Wendy
'15 silverback 29RE
'13 GMC 2500HD
Duramax/Allison
Otegoans is offline   Reply With Quote
Old 02-22-2017, 09:13 PM   #4
Flybob's Avatar
If you have a suburban or Atwood WH, the valves are directly behind the water heater usually hidden behind a panel or drawer. Find the water heater on the outside of the RV then go inside and look for a panel or removable drawer in that area. If water is getting in, the intake side is correct. It could be the bypass valve is open allowing cold water into the hot water side. On some of the newer units, FR uses a 3 way valve on the output side to choose if hot water ( from heater ) or cold water (from cold water line) is fed into hot water plumbing. See Photo below.
Name:	WH Bypass 2 valve.jpg
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 02-22-2017, 10:03 PM   #5
SYE
SYE's Avatar
The bypass is on the control panel outside in the convenience center. It is one of the switches on the panel
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 47 reserved
SYE is offline   Reply With Quote
Old 02-23-2017, 06:19 AM   #6
SYE
SYE's Avatar
This is where they are on my Columbus, yours may be a switch on the panel since it is newer that mine.
Scott & Vicki
bypass, hot water, valve, water
