Old 02-13-2017, 04:50 PM   #1
Caulking or sealant
Hey Guys;
What do you suggest I use for general caulking on my 5r. This would be mostly for trim that the caulking has started to crack and needs to be replaced such as the wheel fenders. I imagine I would use it to touch up in places where it was aesthetics and to stop water penetration. It shouldn't be the self leveling type as this is mostly on the side of the rig.
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
Davidceder is offline   Reply With Quote
Old 02-13-2017, 04:52 PM   #2
Proflex is good in many RV applications.
2017 Coachmen Catalina 283RKS
2004 Chevy Silverado 2500HD Crew Cab
Crabman is offline   Reply With Quote
Old 02-13-2017, 05:00 PM   #3
Need TAN
I am having difficulty finding anything suitable in TAN.
Old 02-13-2017, 05:24 PM   #4
Well I recently purchased some almond colored GE silicone caulk for my bathroom but not sure how suitable silicone is for RV use.
Old 02-13-2017, 08:45 PM   #5
Silicon is fine. Used it for years. But if you need to get it off it really is a bear to do so. It just sticks that well. There are siliconized acrylic caulk that would possibly be a good compromise.
Mdaniels4 is offline   Reply With Quote
Old 02-15-2017, 07:31 PM   #6
I have a gel coat sided trailer and Palomino recommended paint thinner and a plastic scraper to remove adhesive and silicone sealant from the siding. For really tough spots I carefully used a razor blade with lots of paint thinner for lubricant. It has worked well for me. When it's clean I use some glass cleaner to remove any residual paint thinner.
keith_h is offline   Reply With Quote
caulk, seal
