Old 06-12-2018, 10:53 AM   #1
Caulking or sealant
I need to caulk the VERY FRONT TOP of my 5th wheel cap after the existing caulking is removed and the cap painted. Since this is the front top and there is a slight downward curve of the cap is it ok to use self leveling caulk?
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
Davidceder is offline   Reply With Quote
Old 06-12-2018, 11:45 AM   #2
Head Rambler
Yes, it's ok to use self leveling lap sealant, BUT you should consider using Eternabond tape to seal between the roof and front cap.
Gotta go campin!
Old 06-12-2018, 11:51 AM   #3
So, remove all the caulking. Put a full strip of Eternabond? Do I caulk the Eternabond?
Old 06-12-2018, 12:31 PM   #4
NO! Just clean all the surfaces with acetone and the apply the tape and press it down and you're thru.
Old 06-12-2018, 01:56 PM   #5
Sounds easy enough
So I just need to make sure I span the caulking top and bottom the entire length?
Old 06-12-2018, 02:30 PM   #6
Head Rambler
Yes completely cover the caulking with the eternabond tape.
Gotta go campin!
caulk, seal
